Question about Philips Computers & Internet
I need a new monitor base for a Philips 19" 190wv
What size screws go in a Philips 190S6 monitor base?
perhaps checking the Philips website would find what you wish . or check with a local repair shop . I know they get many units they end up junking out .
Dec 27, 2015 | Philips Monitor LCD 19 190S6 Second Hand
Is it possible to rotate the screen (acer al1715sm) from its base? (to srew on the wall) cause mine moves up and done, but gets stuck after a small bit..
find audio multimedia base like VG3P31 (Philips) std. 4 screw mount pedestal like photo below..move up/down, CW, right/left.659ae0f8-3ebc-40d3-ad3a-1dd9b380bafc.jpg
Oct 17, 2013 | Acer AL1715 Monitor
Can I use Philips CD240 CD245 handset on a philips dc445 base
Simple answer yes they are compatable I just did it as I could not find any CD445 handsets.The manuals are downloadable from Phillips just search for CD445 or CD245 manual.Just press speaker button on 445 base for 5 seconds untill it beeps twice,then on new 245 handset menu/ register enter default code 0000 and bingo its live. Oddly the newer handset bases are 9v and not compatable with 445 bases which are 6v and have different contacts so you cant sit your 245 in the old base.My new 245 came with a new base anyway so no problem.
Apr 06, 2012 | Philips Lands Phones
Trying to purchase a replacement parent handset for SCD520?
You can't. I just called Philips and apparently if the parent monitor stops working for whatever reason after the warranty has expired, there is no way to send them off to be repaired and no way to purchase a separate parent model. You are STUCK with buying the whole package again. I have a perfectly good base, but the parent model got into the hands of the child and no longer works. The parent units have to be sold with the base. These parent units are so vulnerable; can't believe there is no way to purchase a replacement. No happy with Philips.
Feb 05, 2011 | Philips Avent Scd520 Dect Baby Monitor
I have a left-right blur on my Philips 170B monitor. Tried resetting several times, but no joy. Can you help? Thanks :-)
if u'r eng. change the crt base in video board or u'can set u'r defocusing prob by EHT focusing section
Dec 12, 2009 | Philips 170B4MG 17" LCD Monitor
Philips 107 E5 Monitor; display compressed into lower half
This is partial frame collapse and can be caused by a power supply issue supply the frame driver or the frame driver circuit has a problem with an IC or driver transistor. It should be relatively cheap to repair at a computer or TV shop but you may want to consider buying a cheap replacement monitor from eBay etc as the repair may cost you more than the replacement given everyone seems to be dumping CRT based monitors in favour of newer LCDs etc.
Aug 30, 2009 | Philips (6G3B11) for 107E51, 61, 107T51, 6...
I'm having a problem assembling my Samsung 2033 sw monitor. The directions are horrible and I don't want to snap the base.
I bought a Samsung 2033sw Monitor and I couldn't get the base attached to the monitor. When I returned it to Best Buy their "geek"
technicians discovered after opening another new monitor that
the spindle was attached to the monitor at the factory. But on
the monitor that I had problem with, the spindle was simply
put in the box along with the base plate. Best Buy solved the problem by disassembling the monitor itself and then installed the complete base assembly. You should return your monitor and asked the sales associate or manager to let you see another new monitor. The only thing you need to attached to the monitor is the round base plate.
Jun 17, 2009 | Computers & Internet
Phillips 42 inch tv
Vendor nap.jpg Part Number 310430814621 Description Stand Base
Tritronics, Inc.
(800) 638-3328
call these guys and they should be able to locate it for you or at least tell you where to get one.
Mar 18, 2009 | Philips Televison & Video
Philips 150S5 lost disc
Check out the Philips site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=150S5FG/27B&scy=us&slg=AEN
You will find product support on the left including software and drivers.
Tom
Mar 01, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
