White screen When I turn it on, theres nothing on it, just a white screen. When I turn it off and then turn it on again, still the same. I can't adjust the volume too, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, they're all the same. But when I adjust it on 0 I here nothing. Please help.
2 Suggested Answers
  • 14 Answers
SOURCE: My samsung 32 inch turns
moa
replace caps in psu panel and eprom or try factory reset switch tv to standby then mune mute info stanby buttin on remote if you get service mune try reset.
Posted on Aug 17, 2010
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
Volume Problems Sharp Aquos LCD TV
Hello Mhursh,
You will have to go into the cable box's menu and adjust the volume control features there as the catv box can control the volume also which is what you are experiencing.
Good Luck!
Rich Lilja
Jun 01, 2017 | Sharp Televison & Video
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Volume control on my keyboard dont work on my logitech LX710
The problem is with the keyboard drivres and you need to reinstall the keyboard drivers and try it again.
Hope this helps...
Feb 02, 2009 | Dell Dimension 2400 PC Desktop
White screen only on E260 4 GB-cannot get to the menu or anything
Adjust the volume while playing by "turning" the thumbwheel. Go clockwise to increase, counterclockwise to decrease.
Jan 05, 2009 | SanDisk Sansa e260 MP3 Player
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
IRiver screen appears but no menu
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Oct 19, 2007 | iRiver H10 MP3 Player
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
