Question about Vissani MVWC52B Wine Cooler
Laid vvissani wine cooler on its back stop working
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
Dec 14, 2014 | Magic Chef Dual Zone Wine and Beverage...
Laid on side, how long wait before plug in?
if there are tubes coming out of the compressor on the side that it was laid over on, then give it 24 hours just to be safe, if no tubes plug it in and let it run
Feb 05, 2013 | Magic Chef MCWC44DZ Wine Cooler
Unplugged the wine cooler to move for painting. When we re-plugged it in it was not working at all. Took off the back and cleaned out any dust from the fan. All of the wires look like they are in place....
First check your breakers. Sometimes re plugging an item can cause a surge and pop the breaker. Maybe some paint might have gotten in the outlet and preventing a clean contact. If all fails, try plugging in the unit in another outlet to see if the problem lies within the outlet or the wine cooler.
Mar 21, 2011 | Cuisinart CWC-1200 Wine Cooler
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
My Haier wine cooler (Model BC112G) has stopped working. Prior to it stopping, the pipes in the lower back became caked with ice. Any ideas what might have broken...and how/if it can be fixed?
let the thing totally defrost (24hrs)with the door open then switch it back on as a first step,the ice on the pipes stops the gas from turning from a liquid to a gas...thats how it cools..
Jun 03, 2010 | Haier BC112G Wine Cooler
Wine cooler just stopped working. light will come
Try disconnecting all power to the unit for about 10 mins, and turn it back on to see if the compressor will kick in. Also check your temp settings and make sure they are properly set. If that doesnt work, you might have a dead compressor which a tech can look at and verify.
DrakeTech.
Mar 01, 2010 | KitchenAid KUWS246E Stainless Steel Wine...
2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
May 13, 2009 | Avanti WCR683DZD Stainless Steel Wine...
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Vissani MVWC52B Wine Cooler Logo
Top Vissani Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Vissani Furniture Expert? Answer questions, earn points and help others
