Question about Saws
Would like to change the blade on a macAllister slide mitre saw cod211lsm
Cant change the blade
thabrain
  • 76 Answers
SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
Posted on Oct 28, 2008
SOURCE: changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Posted on Feb 09, 2009
Editor925
  • 285 Answers
SOURCE: How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
Posted on May 29, 2009
FixYaSteve
  • 57 Answers
SOURCE: how do i change the blade on my delta 10
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Posted on Jun 14, 2010
SOURCE: Changing the blade on a power mitre saw
http://www.superiorairco.com/cgi-bin/workshop.pl
Posted on Jul 20, 2010
I have a Macalister mitre saw with a 210 dia blade with 30mm bore and 24 teeth need a finer cutting blade just wondered why dia of blade I can get in . its 1400w cod211lsm machine
I am not sure.
205 and 210 mm blades are the modern equivalent of the 8" blade. I too wanted a finer cut blade in my mitre saw. I had stock of a couple of 8 inch blades but when trying to fit them I found a 205 went in but a 210 wouldn't. I preferred the 210 so I had to modify the guard a little.
As your blade is already 210 mm you probably won't have any problems with an 8 inch blade or either of the metric equivalents, though it is unlikely a larger blade will fit, if you can find one. The blade designed for cutting laminate provides just about the finest cut.
Apr 25, 2018 | Blade Saws
Mitre saw cod211lsm
Few budget tools and especially generic, brand engineered tools imported from the far east are superbly accurate but tend to be "near enough".
You didn't say whether it is a hand operated mitre saw or a power saw.
Most power mitre saws have a number of stops that can be adjusted or filed in order to calibrate the angles and this process should be done when the saw arrives. Once both 45 degree angles have been calibrated accurately the angles in between should fall into place fairly well.
One problem with low cost mitre (chop) saws, even some so-called professional saws is the construction is so light, when pulling down the handle the machine flexes and spoils the cut. This is especially true when the handle is not set exactly in line with the blade or when not paying full attention when making a cut.
Having experienced such saws I have learned much about them so when I visit a tool store I examine their stock by twisting, rocking and pulling the saw heads and the amount of movement in many new saws of popular brands is disgusting, even some pretending to be premium brands. So far only a few of the most expensive types have impressed me.
That doesn't mean the others are unusable and with care fairly accurate cuts can be made when a suitable technique has been developed - like using a rifle with bent sights...
Nov 27, 2017 | Tools & Hardware - Others
Macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
Feb 26, 2012 | Saws
Saws Logo
136 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
