Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
TV will not stay on...goes into standby mode.
The TV only stays on for 60 secs at a time. Then it goes into standby mode for about 30 seconds, then comes back on for another minute. Then the process cycles again. I have replaced the projection lamp, but don't really think that was the problem. It is still going into standby mode about every 60 seconds.
  • 2 more comments
  • TX Guy Dec 30, 2007
    I have the same problme and looking for some help. I never replaced the lamp becuase lamp warning light doesn't turn on.
    It worked flowlessly for 5 years and now has this issue. Any ideas?
  • albtyler Feb 23, 2008
    Mt tv just started having the same issue. The lamp indicator light does not come on, but the standby light continues to flash. did you find a resolution to this?
  • Anonymous Mar 24, 2008
    I am having the same problem. The TV only stays on for 60 secs at a time. Then it goes into standby mode for about 30 seconds, then comes back on for another minute. Then the process cycles again. I am going to try the fan solution and get the fan repaired, if possible.
  • avivo Apr 06, 2008
    Exactly same problem as the others have described. The TV will not stay on because it keeps going into and out of standby mode.
I have been having the same problems as others are.The continuous cycling on then off would do it all day long if allowed. I had a rear projection tech look at it. He used the remote to do a self diagnostic check on it but and ruled out that it was the processor the most expensive part of the set. He said that on these sets that this problem was caused by 1 of 2 things 8 out of 10 times 1 needs software upgrade so He suggested that we upgrade the software because it was the lesser of the two this did not help either. 2 a new lamp i did replace one already it went out when the set was only 2 years old but have ordered a new one will post when i get the results. good luck jb
Posted on Apr 15, 2008
The red LED for the the lamp may flash which CAN indicate that the cooling fan is not operating. This fan is typically very quiet and has failed on MANY units. It is behind the bulb at the very back of the TV and is not "user serviceable". My repair guy says this is common and you can at least observe the fan through the rear grill and if it is NOT turning, then it IS failing.
Posted on Feb 16, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Ok my tv turns on and only stays on for a few seconds then goes to standby mode. then it will come back on again and it just keeps doing this over and over
Encompass Parts Distribution 1-800-638-3328
they are listing this Model# and Parts.
Have you CK to make sure all Fans are running and when was the Last Time you replaced the Lamp?
Mats has Lamps for $99.00 1-800-628-1118
Oct 24, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
The tv is in standby mode what do i do the tv comes on and stays on for about 2 mintues than the screen goes black and the voices are still there they stay on for about 30 seconds after screen goes black...
could be a problem with the lamp, ballast or power supply board. you really need a technician to troubleshoot this problem. call 1-800-samsung for nearest service center.
Nov 19, 2009 | Samsung - Projection TV replacement lamp...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
