Question about Artograph EZ Tracer Projector - White
Can I use the EZ tracer Projector for slides?
Can't get slide projector to focus with lens in projector
Check the lenses inside the lens tube and see if they are loose or out of place
Feb 05, 2014 | Kodak 4200 Slide Projector
Using the projector with an acer 500 tablet
Not sure the problem set the tablet resoulution to 1024 by 768
Oct 17, 2013 | Mitsubishi Xl1xu/sl2u Lcd Projector User...
Elite screen wont go up with motor
I have a motorised elite projector screen that wont go back up ive replaced batts in remote and checked power
Jul 09, 2011 | Elitescreens 119 in. VMAX Series...
How do i change bulb in headlight on mercury tracer? 1991.
1. Open the hood and remove the screws holding the headlight assembly in place. These screws are located on the back side of the headlight assembly.
2. Slide the headlight assembly forward.
3. Unplug the electrical connector running to the headlight ballast.
4. Slide the new headlight assembly and bulb into place, connect the connector to the headlight ballast and secure the assembly with the factory screws.
Feb 24, 2011 | 1991 Mercury Tracer
When the projector was turned on it started to cycle as when ejecting slides then it stopped and seems to be jammed...the rectangle black screen that opens and closes during the cycle to view slides is...
First of all, remove the tray (use the emergency tray removal in the center hub of the projector). BE CAREFUL not to spill your slides, so before you remove the tray, make sure the tray ring is in position & tight, then when you remove the tray turn it upside down immediately and move the tray plate to the "zero" position. Remove any slides that might be in the gate of the projector. Turn the projector on and cycle the projector 2 or 3 times in Reverse. This should clear a tray/slide jam. Good Luck !!
Jan 24, 2011 | Kodak ABR Ektagraphic 35mm 140 Slides...
Kodak 410 Projector/Viewer - no lite through projector or viewer
These projectors were designed & made by Telex for Kodak.
If the screen stays black when you push a slide down into the "gate" (in either viewer or projector mode), then the trip mechanism that opens the shutters when a slide is detected has a problem. It could be an adjustment, a broken or out of position spring or hardened lubrication.
There is no good way to proceed unless you are trained in the service of these projectors. Contact a factory-trained repair dealer. Happy New Year!
Nov 16, 2009 | Kodak Open Box BC-4601 Slide Projector
I can't find the bulb for my old eumig p8 automatic projector, looked every where, it's a 4 pin bayonet 12v 100w blacktop
Have you tried Projector Doctor on the web? Their toll free number is (800)789-9820. They advertise 24/7 support. Also, All Projectors.com...(800)901-8684. Free calls...start there--they probably could point you in the right direction!---Rick
Sep 07, 2009 | Artograph Projector Bulbs 100 watt -...
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
Slide projector autofocus constantly adjusting
My slide has the remote but remote is not working the projector i have is v5000Af
Jan 02, 2007 | Vivitar V5000AF Slide Projector
Artograph EZ Tracer Projector - White Logo
203 people viewed this question
Top Artograph Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Tom Chichester
Are you an Artograph Office Equipment and Supply Expert? Answer questions, earn points and help others
