Question about Dishwashers
KLEENMAID DW2 MAKING NOISE, WATER IN BOTTOM OF DISHWASHER
  • 641 Answers
SOURCE: Dishwasher not spraying
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Good luck!
Posted on Sep 13, 2007
SOURCE: Kleenmaid DW3 dishwasher not running.
Hello, this isn't a fix, but if you can't get the dishwasher fixed, I am interested in purchasing the cutlery baskets off you, if they are still in reasonable condition. Mine has plenty of breaks in the base and the handles poke through, which affects the lower spray arm rotation. Please reply through another post if you're selling. Thanks.
Posted on Jan 08, 2008
localwonder
  • 6784 Answers
SOURCE: dishwasher not draining and making a noise
Ok, normally, when you hear abnormal noises and the draining has stopped, this will point to the pump/motor assembly. this assembly , basically, runs together in unison. the pump/motor are as one and if the motor is malfunctioning, the pump will not drain properly. this noise is coming from the pump housing. There are many parts that are located in this housing and one fragile part that can cause issues is the Impeller. this piece provides the pump action that moves the water during drainage. If the sleeve that connects to the Impeller becomes stripped, the motor drive bolt will simple spin freely, causing this noise and no drainage. The motors fine but, you will have to replace the pump assembly in order for this noise to stop and the normal draining cycle to return. just to be safe, check all the drainage hoses as well.
please rate and god bless:)
Posted on Apr 01, 2009
  • 70 Answers
SOURCE: My GE 500 dishwasher is making a high pitch noise.
pump running dry(without water)
1)check the water hose connected to the machine(solenoid filter block)
Posted on Jan 08, 2010
  • 10 Answers
SOURCE: Have Kleenmaid "Super silent system"
Dishwasher Doesn't Fill
1) First make sure the water is turned on. Check the hot-water supply stop valve, normally located under the sink. Open it all the way by turning it counterclockwise. If there is no reason this would have been turned off since the last time the dishwasher worked, go on to the next step.
2) Turn off the power to the dishwasher.
3) When the dishwasher is cool, look for the float inside the dishwasher; this is usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring-loaded).
Lift out the float mechanism, and clean around the float tube. Many floats must be disconnected from below; to do this you'll have to remove the lower access panel. Rinse off the float, replace it in the tube, and make sure it moves up and down freely.
4) If you're experienced with minor repair work, shut off the hot-water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel; disassemble the valve to reveal the screen; clean debris from the screen; and reassemble. If the screen doesn't appear to be blocked, call a repairperson (he or she will probably need to replace the water intake valve).
5) If none of this helps, call a repairperson. Any of several parts-including the water inlet valve, pressure switch, and the timer or selector switch-may be faulty.
Posted on Apr 09, 2011
When started, dishwasher making growling (hungry stomach) noise before filling with water
That would be your pump priming, however I would check the sump or filter in the bottom sometimes they get debris caught in them. Some have a filter others have a screen.
Jan 07, 2015 | Dishwashers
Hi my kleenmaid silent system think it's a dw2 the salt button is flashing you turn it on it goes to start then stops we cleaned it all out and fix the problem once before but this time nothing works. I'm...
If water is soft in your area you can ignore the salt indicator light and operate the dishwasher without adding regenerating salt. However, you need to ensure the salt reservoir is filled with water to the brim. So add water into the reservoir and then put the cap back on.
Dec 26, 2014 | Dishwashers
Frigidaire dishwasher is not spraying water from bottom
From what you have described, sounds like the sprayer arms are possibly loose or being held into place and can't rotate, by dishware.
Aug 07, 2012 | Electrolux Frigidaire Professional Series...
My lgis making a horrible noise and is now shoeing an e1 code dishwasher
The LG does suffer from "poor quality" motor that causes this type of noise. The main motor and pump assembly is common to give this type of problem. The pump seal leaks a small amount of water that gets onto the front bearing and causes a "grinding = humming" noise. This can be easly replaced once you have the bottom off and dishwasher on its door. The motoe has 1 screw in the back holding the motor to the bottom and two rubber seals for the water pump in/out into the washer. Just pull and move motor and pump assmbly and it comes free. Replace with a new motor and pump assembly...
Nov 18, 2011 | LG LDF6810ST Stainless Steel Built-in...
Apr 09, 2011 | Fisher DD603B / DD603W / DD603H Dishwasher
My GE 500 dishwasher is making a high pitch noise. There is also no water in the bottom of the dishwasher. I think it might be the water pump.
Jan 07, 2010 | GE Dishwashers
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher making thumping noise when in cycle and leaking
motor turns to cast the water around the dishes.that motor shaft is in close by a water seal.it must have gone bad allowed water on to the motor bearings which would be your noise.could be bad.open your bottem panel turn on unit and watch whats happening.when you see that decide what parts you will need ,check cost and think if thats what you want to do.God bless,tom
Jan 01, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Sep 12, 2007 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
