Question about Vehicle Parts & Accessories
I change already the thermostat but it is still cold
  • 20 Answers
The engine is still cold? Try changing the coolant temp sensor. Unless the vehicle is operating in severe cold climate conditions. Then the engine may not be able to produce enough heat to stay warm. You can try the cardboard in front of the radiator trick to help keep the engine warm. :) I change already the thermostat but it is still co - 2_16_2014_8_44_47_pm.png
Posted on Feb 16, 2014
Tip
How to change thermostat on AUDI 1.9 TDI
Heed of antifreeze solution temperature!!!
You must check the thermostat operating. The thermostat location is on back of alternator at the bottom side of the bracket. IMPORTANT: It is NOT necessary to replace the alternator if you want to change the thermostat !!!
Thermostat checking:
1. Cold engine. Start up the engine and watch of the water temp indicator. After first value 60 Celsius Degree you still warm up the engine until the lifter (pointer) reach 80 C deg. (second mark after 60 C deg.). At this time you let engine running at idle speed and check with your hand the thermostat plastic housing and hose temperature in bottom left side of the engine. Heed of alternator driving belt and ventilator fan !!!
2. If the thermostat is good the hose must be cold until the water temp indicator reach almost 90 C deg.
3. The thermostat opening temperature is 87 C deg.
4. If the hose is already warm the thermostat is out of order.
5. If the thermostat and the temp sender are OK the last piece out of order will be the instrument cluster.
on Dec 19, 2009 | Audi A4 Cars & Trucks
The temperature is to low in my freezer
If you have already tried the thermostat either in the fridge part or on the outside and it doesn't change the thermostat may need changing as if it doesn't tell the compressor to stop making it cold, then the whole freezer just keeps getting colder until the compressor breaks.
Try the thrmostat and if it doesn't work get a service engineer out to fix it.
Shouldn't be too expensive.
GOOD LUCK
Mar 13, 2011 | LG Refrigerators
Heater is cold but abit warm when drivin audi a4 2005
Check & replace the engine thermostat if necessary.
Heed of antifreeze coolant temperature!!!
First time you might check the thermostat operating.
The thermostat location for 2005 Audi A4 1.9 TDI, is on back of the alternator at the bottom side of the bracket.
Thermostat location, Part number: 044121113, in german - "Kuehlregle" (Price around $25):
Important note: Always replace the round thermostat seal, position 7 in the above picture.
Please do rate my response. Thanks!
Feb 09, 2011 | 2002 Audi A6
My heater is blowing cold air already changed thermostat
check the cooling system to see if you have airlock, it may need bleeding after you changed thermo
Feb 04, 2011 | 2001 Chevrolet Malibu
I need to change the thermastat ,,, where is it and whats the easiest way
You must check the thermostat operating. The thermostat location for 1997 Audi A4 1.9 TDI is on back of alternator at the bottom side of the bracket.
IMPORTANT NOTE: It is NOT necessary to replace the alternator if you want to change the thermostat !!!
Dec 04, 2010 | 1997 Audi A4
Temperature guage wont go back to cold after engine shut off. i have already replaced the thermostat.
change the temp sensor / this is eather a coolent temp or engine temp changing the right one will help you
Mar 08, 2010 | 1998 Mazda Pickup
Where is the thermostat on an Audi A4 diesel, 1998
Feb 22, 2010 | 1999 Audi A4
1999 Ford Taurus, no heat. Air comes thru all vents but blows cold air like the ac is on. Replaced thermostat twice, flushed heater core twice, still ice cold air. Help?
Try checking the two pipes that go into and come out of the heater matrix, is one of them hot? if it is there is an air lock within the matrix, Also is the thermostat opening fully? Sorry i know you said you have changed it twice already but take it out check settings when it should open and close, then boil some water and test the thermostat
Dec 30, 2009 | 1999 Ford Taurus
Refrigerator operates properly for a few days then stops working
When you said it stopped working, do you mean it is not working at all? or is it not cold enough? If not working at all, that will be thermostat, when you change the thermostat, did you adjust the small switches to match you unit and make sure wires are connected properly, If not, it would work properly. If not cold enough, check and make sure the condenser fan motor and compressor are running, if both are running but not cooling then you have sealed system problem.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
