Question about Toys
Arctic cat snowmobile drive sprocket chain skippin
    Top Expert:
  • 2,044 Answers
I am assuming you are saying that the Drive Chain is "SKIPPING", inside the Drive Chain, there is OIL and a External Chain Tensioner. Adjust the Chain Tensioner to take care of your Problem of Skipping...
Posted on Mar 01, 2014
3 Suggested Answers
SOURCE: I have a 2002 Arctic
check the crank seals. the sled has only 300 miles but it is almost 10 years old and those seals need to be wet or they dry out and cause a lean condition, therby melting down the closest piston to the seal
Posted on Oct 04, 2011
nutznboltz08
  • 36 Answers
SOURCE: carburater schematics diagram for a 2004 arctic cat 300
Go to http://www.arcticcatpartshouse.com/arctic-cat-atv-parts.aspx?aribrand=ARC#/Arctic_Cat/2004_ATV_300_4X4_GREEN_MRP_%28A2004ATF4AUSS%29/CARBURETOR/A2004ATF4AUSS/A2004ATF4AUSR.
Posted on Oct 13, 2012
Pulled the plug wire off the right cylinder and it killed the engine
Electrical Diagnosis for Arctic Cats - YouTube
? 9:58
https://www.youtube.com/watch?v=iwwl4LPyOCY
Dec 29, 2009 - Uploaded by BlaineDP
When in the "OFF" position the switch will ground the ignition wireto the chassis effectively "grounding out" the ignition systemkilling the spark. ... becomes disconnected or if a wire gets cut then the switch will no longer turn off the engine. ... Testing a stator in a snowmobile Arctic cat - Duration: 3:25.
CAT AS NO SPARK!! - American Snowmobiler Magazine ...
cs.amsnow.com > ... > Forums > Manufacturers > Arctic Cat snowmobiles
If the connection to any switch; key, kill, tether, throttle safety switch, etc.. is ... Some older model Arctic Cats have the ground up closer to the handle bars on ... Here is a general rule of thumb for putting spark plug wires on which cylinder for Cats: ... Pulledthe ECU cover off and found some corrosion; I had a 580 that did not ...
Jan 16, 2016 | ATVs
Tip
How to chage the belt on anny arctic cat snowmobile with diamond drive
to change a belt on a arctic cat snowmobile with diamond drive. your owner's manual will tell you to use a tool to let the clutch faces separate and so on. there is a much eyeser solution. there is a signal alen key bolt that holds the clutch to the diamond drive assembly. put this alen key in your tool kit and when ever you need to change the belt just undo this bolt remove the cluch from the diamond drive place belt on cluch and with minimal force replace the clutch on the shaft on the diamond drive then tighten the bolt.
on Aug 03, 2010 | Sport & Outdoor - Others
94 artic cat zr580,wont move revs up to 4500rpm, idles have bypassed all switches,new primary coil,
If your drive clutch is ingaging take a look at your chain. It may have broke.Common problem!
Apr 12, 2014 | Arctic Cat Winter Sports
Chain case bearings leakings arcticcat saber
Put a dual sealed berring in the lower chain case and make sure the o ring arount the berring is good and in place.
Mar 16, 2014 | Arctic Cat Sabercat 600 EFI LX Winter...
2002 arctic cat 509 track clicking noise near fron sprocket
If the sled is picked,look for any torn ones that may be hitting the tunnel. Or take a look at your drive shaft berrings.
Mar 04, 2014 | Arctic Cat Winter Sports
Arctic cat zr900
Open your chain case. Youll probably find your chain laying in the bottom.
Mar 03, 2014 | Arctic Cat 2008 CrossFire 8
Need to find replacement for broken belt/track.
Belts for cleated tracks are no longer available from arctic cat. You will have to find a used belt on EBAY, at a salvage yard, or upgrade to a rubber track. An Arctic dealer can look up pieces needed to upgrade to rubber track from the old accessory parts listing to do the upgrade. You will need to replace your drive sprockets and possibly the drive axle to run a rubber track with out cleats.
Oct 24, 2010 | Interactive Toy Concepts Crossfire Arctic...
Toys Logo
54 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
