Question about Hardware & Accessories
I have the Stalwart 73-Compartment Tool Box. How many compartments are in each tray and is each tray the same?
There are four trays in each of these toolboxes. Each tray is identical to the other and each has 18 little compartments. The top storage area is one large compartment that is not divided. It is not an option to customize these trays or their compartments in any way.
Posted on Feb 16, 2014
How can I clear defrost water drain tube?
You need to find a suitable tool to clean the tube without destroying it. I have found a chopstick is good for reaming out "gunk". After the "gunk" has been deposited in the tray underneath, pick a time when the defrost cycle has not just filled the tray and remove it for a thorough cleaning and reinstallation. If this last step is not followed, you will become aware of something that doesn't smell quite right in the vicinity of the refrigerator.
Apr 06, 2016 | KitchenAid Kitchen-Aid Bottom Freezer 24.9...
Where are the fuse boxes on fiesta zetec s petrol 2009
Fuse box is located in the glove compartment. Empty the glove compartment, then the side will pop out for access to the fuses.
Aug 28, 2014 | 2010 Ford Fiesta 1.25
Ford figo fuse box location
Fuse boxs location:
  • The engine compartment fuse box is attached with the battery tray in the engine compartment.
  • The passenger compartment fuse box is located behind the glove box in the instrument panel.
On this website (link below) you find fuse box diagram (layout) and description for Ford Figo
Ford Figo 2010 fuse box diagram India version Auto Genius
Sep 26, 2013 | Cars & Trucks
How to insert simcard
Depends on what you have. iPhone 4/4S, 5 will have a sim compartment on the right hand side of the phone, with a small hole in it. Use the sim removal tool or an earring and push it in that hole, the sim tray will pop out. Insert sim in tray, and insert tray in phone. There you go.
Apr 17, 2013 | Apple iPhone Smartphone
I have a dlp 73in mitsubishi tv and i have sparking in the long box next to the bulb housing
check to see if the lamp connectors inside the lamp compartment didnt get pushed back inside the set. If they are still there secure inside the lamp compartment then you will need a new ballast which you can get from www.tvrepairworld.com
Feb 22, 2012 | Mitsubishi WD-73732 73" Television
Where is the fuse panel for a 2005 ford focus four door
Passenger compartment fuse panel
The fuse panel is located below and to the left of the steering wheel by
the brake pedal. Remove the CD stowage box to access the fuses.
To remove a fuse, use the fuse puller tool provided on the power
distribution box cover located in the engine compartment.
Power distribution box
The power distribution box is located in the engine compartment. The
power distribution box contains high-current fuses that protect your
vehicle’s main electrical systems from overloads.
For this and other details can check the 2005 Ford Focus - Owners Manual (page 148 and next).
Hope help with this (remember rated this help). Good luck.
Jul 05, 2010 | 2005 Ford Focus
Where is the fuse box that controls the windows? and the horn i dont see it in the engine compartment
behind the battery in the engine compartment and behind a pull-out tray on the lower dash to the left of the steering column.
Sep 11, 2009 | Chrysler Sebring Cars & Trucks
Windows will not go up or down. cannot find fuse.
it is located under the spare compartment above the hood release. You simply pull off the compartment unit and the fuse box is inside. You should find your spare fuses and your fuse pull tool. To install the compartment unit again just set the bottom part on the lip and close it, you'll hear a metal click and you are good.
Jun 25, 2009 | 1990 Nissan Pathfinder
Need to change Cabin air filter in 2006 Acura RL
Hi,welcome to fix ya. its behind the glove box . Just open the top compartment inside the glove box (button in the middle) and pull the compartment out it has velcro and plastic snaps on the back side > Then grab the compartment by the outside and push the lock tabs in and pull the tray with the cabin filter out and change the filter.31ffbbc.jpg
Feb 24, 2009 | 2005 Acura RL
My cd/radio all the sudden stopped working maybe fuse??
There are two fuse boxes. One is located on the kick panel in front of the passenger side seat. Remove the big cover. Inside there is a second cover that ultimately gets you to the fuses. Try #20 (reference the template on the inside of the cover). There is a second fuse box (high current fuses) inside the engine compartment (on the passenger side of the compartment, big square plastic box). Fuse # 56 (reference the template inside the cover of the fuse box). Same deal.
By the way, there is a fuse removal tool inside the interior fuse box (white plastic piece on the left side of the box). You will need that removal tool to work on the ones in the engine compartment. That other box doesn't have a tool.
Hope this helps.
Nov 17, 2008 | 2006 Ford Mustang
Hardware & Accessories Logo
367 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
