Question about Audiovox VE1020 10.2 in. TV/DVD Combo
Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
DVD - VCR magnavox player... model # mwd 2206...when vhs is inserted it will begin to play the tv but than shuts off....while the words eject c is across screen...put it on dvd player it will also shutoff...But if you put vhs tape in at the same time turn on dvd you can watch dvd...but still will not play the vhs....help!
  • 3 more comments
  • sdbio Mar 26, 2008
    Same problem, but now it will randomnly turn off and won't stay on
  • Zerk777 Jul 02, 2008
    i have a magnavox 27in combo that does the same thing and also now randomly cuts off, last week it went through a phase where it wouldn't cut on at all now its back to random
  • Anonymous Aug 14, 2008
    when combo is turned on eject C is on tv screen then switch over to dvd that plays for 5 sec and then the combo shuts off.
  • ajhohman Jan 25, 2009
    Same experience. DVD/VCR shuts off after playing for 4-5 seconds. I guess that is why it was $50. It worked fine for about a year, which makes it impossible to return. Smart on manufacturers part.
  • Anonymous May 18, 2009
    sucks plays dvds fine but wen i put in my kids old vhs tapes plays foe about 20 sec then shuts off an ejects
I have the same unit (Magnavox DVD/VCR MWD 2206). If the top cover was removed, the DVD player would work fine. But if the clear plastic sensor post on the VCR side is covered, the unit would shut off. I removed the screw holding the sensor post in place and cleaned the led light under it using a cotton swab with rubbing alcohol on it. Then I screwed the clear plastic sensor back in place and cleaned it the same way. The unit now works great!
Posted on Jan 09, 2012
  • MEL LANHAM Aug 04, 2013
    YOU NC JUST FIXED 1000 UNITS, THANKS MEL CHARLOTTE
  • 3 Answers
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Posted on Jul 07, 2009
I have a Magnavox dvd player/ vhs MWD 2206. It does not switch between dvd and vhs play modes. It stays on the dvd screen no matter what I do. The light goes on to indicate which is supposed to be in use...
Software issue since unit is not recognizing the tape. Try a hard reset and see if that clears up the cobwebs. U might also check to see if there is something in the vhs tape path that sends a signal to the main board for switchover.
Aug 25, 2017 | Televison & Video
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox vcr/dvr. insert vc tape, machine loads and plays tape for about three seconds then stops and ejects tape. tape will not stay playing. thanks, larry
Mine does the same.It's basically junk.A new VCR/DVD player goes for around $80.If you were to call to ask about getting your VCR repaired,they would tell you that it is FAR cheaper to simply purchase a new one.Same Magnavox I bet almost too.model # for mine is MWD 2206.Labor alone is easily at least $60/hour and it would take that just to disassemble and reassemble the VCR section just to get at the problem.Greg
Feb 10, 2011 | Televison & Video
Have a Magnavox DVD/VCR player Model MWD 2206A,
units like DVD's, have the tendency of malfunctioning if not used for quite sometimes.corrrect me if i'm wrong.but like automobiles needs tune-up, right?try power it on for some time, but not using it.if still not call a tech
May 13, 2009 | Philips Magnavox DVD/VCR Dual Player
Free download user manual
i have Philips Magnavox MWD 200G model dvd player purchased in usa and put to use in India.it was rep[aired due to high voltage.later it is showing disc error for any cd or dvd whilke playing and indicvates that the play back feature nay not be available on this disc.but it plays Fuji Film DVD R.please advise me how can i solve the issue for playing the other cds or dvds
Mar 10, 2008 | Philips Magnavox DVD/VCR Dual Player
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox DVD.VCR player.
The remote code for magnavox dvd/vcr dual player is, 21593. It work for me..
Jan 21, 2008 | Philips Magnavox DVD/VCR Dual Player
Audiovox VE1020 10.2 in. TV/DVD Combo Logo
1,708 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
