I'm in search of a tropby radio controlled clock, with aa batteries, can someone help me with that? It has 5 alarm positions, and I can't solve this problem, at 9h20 and at 12h20 it rings.
SOURCE: Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
SOURCE: How to change the time on clock radio
I'm not 100% sure if this is right or not, but i used to have one similar and the way to reset it was:
Give this a try and hopefully it works, good luck
SOURCE: Instruction Manual for Timex Alarm Clock Radio T309T
Here is a website for the manual:
http://www.timexaudio.com/product_manuals.asp
You have to find the product number, located on the bottom. EX: T-309
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
SOURCE: alarm clock GE model no. 7-4894A but no manual
You can down load the manual on link below for free.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
Good Luck and please rate 4 thumbs up for the free answer.
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time. OK.
Ok.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
