Question about Panasonic LUMIX DMCZS7 DMCTZ10 Digital Camera
Smeg c10 v1 xx door removal - Panasonic LUMIX DMCZS7 DMCTZ10 Digital Camera
Spilt milk inside Smeg oven door
no use crying over it :>)
Get an old towel and soak it in hot water. Put baking soda over the stain, then the towel and wrap the door in cling film. Leave overnight. Wash off with hot water.
If it is between the glass in the door, then you have to remove the door, remove the screws holding the two halves of the door together and then do the above.
Feb 21, 2016 | Smeg Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
How do I remove Smeg FAB 28 Fridge door,as I have bought a new replacement but it has not instructions
remove the top of the fridge by removing the two screws on the back of the top and sliding the top to the back. that gives you access to the doorhinges. remove the three screews of the lower hinge, which allows you to remove the door from the upper hinge too. (sorry, non native speaker)
Oct 05, 2009 | Smeg FAB28
How can you tell if it is a version 1 or 2?
Sansa e200 series has 3 not interchangeable versions of firmware:
  • version 1: e200, firmware starts with v1.xx.xxx
  • version 2: e200v2, firmware starts with v3.xx.xxx
  • version rhapsody: e200r, firmware starts with v1.xx.xxx
Site for the difference between these versions:
http://kb.sandisk.com/app/answers/detail/a_id/193
The exact type should be on the back of the player: model e280R.
For the rhapsody there is only 1 firmware available.
The zip file can be downloaded here:
http://mp3support.sandisk.com/firmware/rhapsody-1.0.2.165.zip
When another firmware is needed, go to the download firmware wizard on next page and select your model:
http://www.sandisk.com/sandisk-support/driver-download-wizard.aspx
Sep 25, 2009 | SanDisk Sansa E280 MP3 Player
Smeg F170-5 door joint broken
The door is removed by rotating, on both sides of the door, a clip on the lower of the two struts that connect the door. The clip rotates up and then engages a hook on the upper clip so that the two are held together by the spring mechanism to allow the struts to be lifted out when the door is in a 45° angled position. With the door off there are three screws on the bottom of the inside that allow the inside window assembly to slide off, allowing the parts to be replaced.
Sep 14, 2009 | Smeg S351X/5 Electric Single Oven
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
We have a smeg microwave and my wife slammed the door and now i doesnt work could it be the fuse?
If it's dead, it could be a fuse.
If it won't work properly, the door switch mounts or door hinges are out of alignment or broken.
The outside cover will have to be removed so the interaction can be observed between the hook-like door latches and the door switches as you open & close the door.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 02, 2008 | Smeg Microwave Ovens
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Panasonic LUMIX DMCZS7  DMCTZ10 Digital Camera Logo
20 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
