Question about Nokia N70 Cellular Phone
Can,t get tools on menue button
No service shows on phone
What are the codes for Samsung Android phone
Samsung secret code by Mubarak Sulaimon
*#06# - IMEI number
*#0*# - Enter the service menu on newer phones like Galaxy S III
*#*#4636#*#* - Phone information, usage statistics and battery
*#*#34971539#*#* - Detailed camera information
*#*#273282*255*663282*#*#* - Immediate backup of all media files
*#*#197328640#*#* - Enable test mode for service
*#*#232339#*#* - Wireless LAN tests
*#*#0842#*#* - Backlight/vibration test
*#*#2664#*#* - Test the touchscreen
*#*#1111#*#* - FTA software version (1234 in the same code will give PDA and firmware version)
*#12580*369# - Software and hardware info
*#9090# - Diagnostic configuration
*#872564# - USB logging control
*#9900# - System dump mode
*#301279# - HSDPA/HSUPA Control Menu
*#7465625# - View phone lock status
*#*#7780#*#* - Reset the /data partition to factory state
*2767*3855# - Format device to factory state (will delete everything on phone)
##7764726 - Hidden service menu for Motorola Droid
Update x1: More codes!
*#*#7594#*#* - Enable direct powering down of device once this code is entered
*#*#273283*255*663282*#*#* - Make a quick backup of all the media files on your Android device
*#*#232338#*#* - Shows Wi-Fi MAC address
*#*#1472365#*#* - Perform a quick GPS test
*#*#1575#*#* - For a more advanced GPS test
*#*#0283#*#* - Perform a packet loopback test
*#*#0*#*#* - Run an LCD display test
*#*#0289#*#* - Run Audio test
*#*#2663#*#* - Show device's touch-screen version
*#*#0588#*#* - Perform a proximity sensor test
*#*#3264#*#* - Show RAM version
*#*#232331#*#* - Run Bluetooth test
*#*#232337#*# - Show device's Bluetooth address
*#*#7262626#*#* - Perform a field test
*#*#8255#*#* - Monitor Google Talk service
*#*#4986*2650468#*#* - Show Phone, Hardware, PDA, RF Call Date firmware info
*#*#1234#*#* - Show PDA and Phone firmware info
*#*#2222#*#* - Show FTA Hardware version
*#*#44336#*#* - Show Build time and change list number
*#*#8351#*#* - Enable voice dialing log mode, dial *#*#8350#*#* to disable it
##778 (+call) - Show EPST menu
These codes are specific to HTC devices only:
*#*#3424#*#* - Run HTC function test program
*#*#4636#*#* - Show HTC info menu
##8626337# - Run VOCODER
##33284# - Perform field test
*#*#8255#*#* - Launch Google Talk service monitor
##3424# - Run diagnostic mode
##3282# - Show EPST menu
##786# - Reverse Logistics Support
WLAN, GPS and Bluetooth Test Codes:
*#*#232339#*#* OR *#*#526#*#* OR *#*#528#*#* - WLAN test (Use "Menu" button to start various tests)
*#*#232338#*#* - Shows WiFi MAC address
*#*#1472365#*#* - GPS test
*#*#1575#*#* - Another GPS test
*#*#232331#*#* - Bluetooth test
*#*#232337#*# - Shows Bluetooth device address
*#*#8255#*#*
This code can be used to launch GTalk Service Monitor.
Codes to get Firmware version information:
*#*#4986*2650468#*#* - PDA, Phone, H/W, RFCallDate
*#*#1234#*#* - PDA and Phone
*#*#1111#*#* - FTA SW Version
*#*#2222#*#* - FTA HW Version
*#*#44336#*#* - PDA, Phone, CSC, Build Time, Changelist number
Codes to launch various Factory Tests:
*#*#0283#*#* - Packet Loopback
*#*#0*#*#* - LCD test
*#*#0673#*#* OR *#*#0289#*#* - Melody test
*#*#0842#*#* - Device test (Vibration test and BackLight test)
*#*#2663#*#* - Touch screen version
*#*#2664#*#* - Touch screen test
*#*#0588#*#* - Proximity sensor test
*#*#3264#*#* - RAM version
May 04, 2016 | Samsung Cell Phones
Phone is fully charged but I it won't open what can I do?
1- Remove the battery.
2- Insert the battery.
3- Press Volume up + Home button + Power button (all together)
4- When the phone vibrate release the power button and keep pressing the other two buttons.
5- A service menu will show up on the screen
6- Navigate the menu with Volume Up and Volume Down and Power button to select.
7- Choose "reboot system now"
8- If the problem is not solved by now you may need to repeat the process but instead choose "wipe data/factory reset" in the menu. Beware that this option will erase everything you have in the phone like photos, files, phonebook, everything.
Take care.
Oct 14, 2015 | Samsung GALAXY S4
Reset factory settings
  1. Hello please try the below steps to reset the printer:
    1. Hold down the "Resume" button on your Canon printer for one to two minutes, and then release the button. In some instances, this may reset the printer automatically.
    2. Unplug the power cable from the back of the Canon printer if the printer did not reset when you held down the "Resume" button. Hold the power button down and plug the power cable back into the Canon printer. Do not release the power button.
    3. Press the "Resume" button on the Canon printer two times and release the Canon's power button. The Canon printer resets to the factory settings and the ink level should appear full.
    If you will need more help you can download the service manual for canon ip6000d from the below link:
    http://goo.gl/gAqyP
    Thank you
Jun 26, 2013 | Canon Pixma iP6000D InkJet Photo Printer
How to fix a broken button on my cell phone
you need to show some repairer to open your device and fix magnate of menu button and maybe change keypad.if you are able to do it your own ,you will need some tools to assembly and dissmbly the device, search on you tube how to assembly and dissmbly your device.
Jun 22, 2012 | Samsung Cell Phones
I open my yahoo mail account and it opens but nothing shows. The tool bar is there and shows inbox etc but nothing is there
You can download and install either Google Chrome or Mozilla Firefox.
If you wish to continue using your current browser, open the browser window and click the "Tools" button from the menu bar. From the drop down box select "Internet Options". Click the "Advanced" tab and click the "Restore advanced settings" and "Reset" buttons, clicking OK to the dialog box following it. Close the browser window and browse back and you should have the page back to normal.
Aug 24, 2011 | Yahoo Mail
How to uninstall unnecessary applications from phone memory of N72. As again n again my phone is showing error message that memory full unable to perform any operation delete some data. I am unable to...
Follow the steps :
Press the Menu button (oval-shaped icon) on your keypad, and then select "Tools."
Select "Manager" from the Tools menu. Scroll down and find the program you want to remove.
Press "Options" and choose "Remove." At the prompt, select "Yes" to confirm. This will uninstall the program from your Nokia N72.
Feb 20, 2011 | Nokia N72 Cellular Phone
How to reset the lg rumor
If you have forgot the codes for your mobile you can unlock it by using the last four digits of your phone number or four zeros. If these codes are not working you can contact your network service provider to get the unlock codes.
If you need to reset your mobile then press the "Menu" button,from main menu scroll to "Settings/Tools" and select the option by pressing the center "Menu/OK" button.Scroll to "Settings" and select.Scroll and select "More". Scroll to "Security" and press your "Menu/OK" button.Enter in your phone's security code when prompted. Select "Reset/Erase", then "Reset". A warning message will appear. Press the "Menu/OK" button, then highlight and select "Yes" to confirm the reset.
Thank you !!D
Oct 30, 2010 | LG RUMOR Cellular Phone
Keeps showing 'add ink' after adding inks & turning off/on again
This method was for 8500/8550, but we have a 8560mfp and it worked for us (with some slight modifications...). Skip step #1 and do this instead to get to the Diagnostic Menu
Click the "System" button. Select "Information", then "Troubleshooting" then "Service Tools", and finally "Enter Diagnostic Mode".
"OK" below means the check mark button on our printer.
"This may include: Low ink error, add ink error or 09,035. Error codes and more.
1) Press and hold the red button (info button) and the "OK" button simultaneously. This should take you into the Service Tools menu.
2) When in the Service Tools menu, scroll down to the "Enter Diagnostics" menu. Select the "OK" button. It will go through some cycling at this time for about 2 minutes. The screen may go blank a few times too.
3) It then asks for a confirmation, select "ok" again. The printer will go through a minute of rebooting. The screen may go blank a few times too. You are waiting for the diagnostic menu with the Test #00 "no test selected"
4) At this point hit the down arrow button until you reach the test #76. Select "OK"
5) It will ask for a confirmation. Select "OK" to confirm.
6) Then hit the down arrow button again and select the next test #75. Select "OK"
7) It will ask for a confirmation. Select "OK" to confirm.
8) Then hit the up arrow until you go over test 100 to test 01. "Exit diagnostics."Select "OK".
9) It will ask for a confirmation. Select "OK" to confirm.
10) At this time the printer will again reboot for several minutes
Oct 13, 2010 | Xerox Phaser 8560MFP Laser Printer
I need to restore NVRAM from the WorkCentre 2424.
1. From the System Setup menu, go to Information --> Troubleshooting --> Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
If that doesnt work try below.
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads 'Beginning Service Mode Initialization'. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. You should find it in the function sub menu.
Jul 16, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Jun 03, 2009 | Xerox Phaser 8560DN Laser Printer
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
