Question about Element Electronics PHD42W39US 42 in. Plasma TV
White screen with sound - Element Electronics PHD42W39US 42 in. Plasma TV
Have an Lg tv that when turned on has a white screen. Model # LX6500-UB.
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 25, 2015 | LG Televison & Video
White screen
Hello
White screen with or without sound? If you have sound maybe motherboard or panel (or Tcon module)
Best take it to the nearest authorized Samsung service.
Regards
Apr 10, 2014 | Samsung LA32D403E2 HD LCD TV
Screen went completely white but still have sound
Try with the Mitsubishi remote the soft restart, set on Menu,1,2,3, and enter.
Dec 07, 2012 | Mitsubishi WD-65734 65" HDTV
Sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
May 11, 2012 | Sharp LC Televison & Video
My Sylvania 32" just had the entire screen go
My Sylvania 32" just had the entire screen go white. There was still sound but the picture was gone and just the white screen. Any ideas?
Oct 11, 2011 | Sylvania 32 in. Diagonal LCD HDTV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Element Electronics PHD42W39US 42 in. Plasma TV Logo
23 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
