Toshiba Qosmio G20-120 spontainiously set bios password
SOURCE: Toshiba Satellite A100 spontainiously set bios password
I had the same problem, muchos gracias! The hardest part is removing the piece of plastic. I jammed the tip of a very small flat headed screwdriver underneath the black edge facing the keyboard, directly beyond the F1-F12 keys. There are 5 clips along that edge, you need to make them click out. There are no clips along the side or back edges. The black plastic covering the screen hinges are part of the same piece of plastic, and these each have one clip on them, so after all 5 (evenly spread) clips along the front edge have come out, tilt your screen back its full extent - on my laptop, it goes flat, and then tilt the plastic front edge of the plastic up a few degrees; a little less than a 35 degree angle, and then whilst keeping that front edge at the same distance away from the computer; not without lowering it more than perhaps a little, put your fingers underneath and gently lift the back edge and the hinges away from the computer, be gentle as the clips on the hinges are the same thin clips you can now see along the front edge.
Once you have removed this, undo the two screws, and do not unplug the keyboard - it's not too difficult to plug back in, but adds unnecessary work. To remove the small card under which the C88 solder points may be found, pull the silver metal clip that is holding it in left, away from the board. I did this with a flat headed screwdriver again, but that's unnecessarily brutish. Do not remove the two wires, you won't be able to re-attach them without a little solder (or I suppose, cellotape!). Under the board you will find two neat rectangle blobs of solder, and just to make doubly sure, they're labelled C88 just above them, but as they're the only solder points in sight it's quite obvious :).
Thanks very much for this solution Rochelle (I won't say r0chelle; I assume the name you wanted was already taken!).
Posted on Jan 23, 2009
  • 84 Answers
SOURCE: toshiba Qosmio g15 av501 Bios password lost
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on May 19, 2009
  • 4090 Answers
SOURCE: Toshiba sat A135-S2266 BIOS password reset?
Ok turn the unit over to where the RAM is open the door( Toshi in off mode) remove both rams and look for two brassy flat peices of metal. Take a paper clip and bridge the two together...woosh !
Bios is reset.. no password. replace ram correctly close the door and start laptop as normal.
Please rate our help to keep service online
Posted on Aug 20, 2009
SOURCE: reset bios password in satellite 1135
remove the power cable, batter and the cmos battery from the computer, wait a couple of minutes and reassemble. The bios with the password will be reset.
Posted on Oct 10, 2009
mariolands
  • 2296 Answers
SOURCE: i need to reset the
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Posted on Dec 24, 2010
Toshiba qosmio f15r how to found bios jumper
Try Toshiba technical support forums, if you have a BIOS password that youre trying to get around, unfortunately the only way is to contact toshiba.
Jan 08, 2013 | Toshiba Computers & Internet
CLEAR CMOS PASSWORD FOR Toshiba Qosmio G35-AV600
Read the Manual.
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and search them for Bios Password or Bios Password Reset.
May 24, 2012 | Toshiba Qosmio G35-AV600 Notebook
Need to clear bios password on qosmio g-35 av600 cannot load recovery disks unless i can enter bios password
Laptops can be quite tricky to clear out. Only thing I can do is tell you to unplug the laptop. Remove the battery. Try to turn it on for about 10 seconds repeatedly ( this drains latent power from the main board) Put the battery back in, plug it in and give it a whirl. Hopefully that will be enough to clear the bios.
Mar 30, 2011 | Toshiba Qosmio G35-AV600 Notebook
Toshiba G35 bios password
Read my instructions here to reset the BIOS password: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
Before you proceed please be aware that most Toshiba laptops have the CMOS battery soldered to the motherboard and you will need a soldering kit to remove it and put it back.
Feb 25, 2011 | Toshiba Qosmio G35-AV600 Notebook
Como puedo recuperar mi password de un toshiba qosmio en la bios
You should take a risk or take help from your local technician.Because this password is not recoverable, with the simply remove the cmos battery , it is placed behind the cmos chip .please follow the link.
There are many option just follow them and try to solve.
http://criggie.dyndns.org/laptop/tecra530cdt/toshibapassword.shtml
http://jevarax.wordpress.com/2008/08/08/how-to-clear-your-toshiba-bios-password/
Another proceses
http://www.laptoprepair101.com/laptop/2006/02/10/remove-clear-toshiba-laptop-bios/
Hope this helps
Jan 19, 2011 | Toshiba Qosmio G45-AV680 Notebook PC
Como obtener el password de un toshiba qosmio con bios phoenix
This password is your backdoor password behind the BIOS chip,you can not reset only remove the cmos battery.You should take a risk ,if you do not do please take a help by your nearest technician.
Repair4Laptop: BIOS Password Reset and Recovery for Laptops & Notebooks
Hope this help.
My daughter put a password for the bios and cant remember it.
Try holding down the "Left Shift Key" when turning on the system
Nov 28, 2008 | Toshiba Qosmio G15-AV501 Notebook
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
