Question about Danskin Now Girls Racerback Tank
Can you tell be if this is made from a tretchy fabric or cotton?
It is stretchy, made out of 100% polyester and I think it says it all...
Posted on Feb 16, 2014
What stitch should I use to sew stretch cotton fabric
Hard to tell because your machine is unidentified.
Jul 14, 2017 | Sewing Machines
What is the difference between all of the fabric options?
Fabrics are available in White and Unbleached Cotton Terry, Bamboo Terry and 100% Organic Cotton Terry and Stay Dry. But it is recommended that you should use cotton diapers for your baby as they are best and rash free. To get more details about diapers for your tiny tods you may look on Windeln.
May 06, 2017 | Washing Machines
HOW DO I GET INK STAINS OUT OF A WHITE COTTON SHIRT?
Rubbing alcohol or methylated spirits (denatured alcohol) from the drugstore or hardware store are ideal to remove ink stains, as long as the stains have not set. The alcohol neutralizes the pigment in the ink so it disappears. Either soak a washable garment in rubbing alcohol or methylated spirits, then wash as normal,[2] or use the following process:
  • Dip a clean cotton swab into rubbing alcohol.
  • Dab at the soaked up ink mark with the cotton swab (bud) or small sponge.
  • Repeat this each time with a fresh cotton swab or sponge, as many times as needed.
  • Dip another fresh cotton swab or sponge into cold water and dab the area to remove the alcohol from the fabric. For best results, let the fabric dry before trying to remove the ink stains again. Rubbing alcohol works best on a dry fabric, but after each application you must rinse it with water. The process of removing heavy ink stains is a lengthy, cyclical process of blot, rinse and dry.
  • Allow the area to dry. Wash the garment as normal.
cheers
Mar 03, 2015 | Dryers
What would a typical tension number be for a cotton fabric? mine is loopy or tight right now
you didn't mention the name and model number of the sewing machine or serger... is the loopy thread on top or bottom? when is the thread tight? what type of cotton fabric,, solid cotton--polyster cotton? normally mine stays on 4 or 5 --depends on fabric I'm sewing..
Dec 15, 2014 | Sewing Machines
Why is my brother ls2160 is sewing fine on cotton but not on the material I am using. Its a stretchy silky kind of material. What am i doing wrong?
You may need to use a walking foot with your machine as stretchy fabrics are hard for the feed dogs to 'grip' and pull the material through under the needle.... you will probably need to change needle as well... there should be a helpful video on YouTube that will tell u all about sewing with stretchy fabrics and how a 'walking foot' works... hope that helps.
Jul 20, 2014 | Brother LS 2160 Sewing Machine
It rattles....even with the grill off....sounds like tubes rattling but I can't tell
There could be a small tear in the plastic liner over the speaker. If thats the case you can try pressing some cotton on it and then put the grill back in place, or find some fabric glue and glue a thin peice of fabric over the tear.
Mar 20, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
Skipped stitches
Try some Schmetz brand needles, they skip less than any other brand. If that does not solve the problem, you need to have it serviced.
Jan 15, 2011 | Bernina Artista 180
Cotton/sturdy button not working on the select fabric
"I have the maytag neptune mah5500bww. the cotton/sturdy button" it has an led read out.
Jul 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Stitching tension
hi,
different fabrics and layers has diferent set up on threading. try cotton fabrics w/ thread tension of #3 to #4 and stich # 8 to #12.if you change fabric and layers gradual setting on dial tension should be done until you acquired the good set up.have a nice day.regards
May 29, 2009 | Singer 8280 Mechanical Sewing Machine
In what order do i put the tension assembly together
Probably the most important contol on your machine is this one that regulates your top thread tension there are reason for having to reset your tension.Classified your fabric that you are using there are several set up of tension in every fabric that you use.Cotton fabric is most easier other than silk fabric make a record on this set up.The required tension depend upon the stiffness of the fabric,thickness,layer of rabric to be sewn and required stitches.Try cotton fadric turn tension dial to N0. 3 and Stitch set to from 8 to 12 defend to what is nice to you.
Mar 07, 2009 | Necchi Sewing Machines
Danskin Now Girls Racerback Tank Logo
426 people viewed this question
Top Danskin Now Clothing Experts
Da Doc
ray gallant
Erin Wood
Erin Wood
Are you a Danskin Now Clothing Expert? Answer questions, earn points and help others
