Question about Motorola Radio Communications
Motorola HX550 headset goes dead after 30 minutes.
I just bought the headset a month ago and fully charged it. When I put it on, the voice says "fully charged ". The battery charge has never lasted more than 30 minutes since I got it. It is paired with my iphone 5.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Maybe a fault. Try charging it a lttle more n leave it on a bit longer? if not you may have a duff one so just take it back!
Posted on Feb 17, 2014
Cpyles07
  • 56 Answers
SOURCE: Motorola H700 wont sync with my Palm Treo phone?
Did the headset become unpaired with he phone? If so make sure the boom is closed and Hold down the button on the side until it starts to blink then run the wizard
Posted on Dec 06, 2007
SOURCE: Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Posted on Sep 14, 2008
SOURCE: Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Posted on Jul 13, 2009
SOURCE: Trying to pair my Motorola Headset H681 with my
the pass key is 0000
Posted on Jan 01, 2010
award462
  • 395 Answers
SOURCE: Motorola H170 headset problem
Try charging it for 24 hours, this should reset the headset. then completely delete the pairing and repair the device. If this doesn't work, there could be a problem with the mic portion of the headset.
Posted on May 05, 2010
Power level notification every minute. Very annoying. Can't stop it.
Hi Jim,
In this link Motorola Support Find Answers Motorola Mobility Inc you will find all information regarding your device.
Regards,
Maya
Motorola Support
May 03, 2016 | Motorola Mobility Hx550 Bluetooth Headset...
Constant beeping in bluetooth, and will let me use voice command to call but not text.
Cathy
This headset doesn't work natively for voice dictation unless you initiate listing via your phone. There are specific headsets that do facilitate voice to text but it is specific headsets with certain phones and may require an additional app.
https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/71063 https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/71063
Dec 29, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
Why I can't hear caller's voice with HX550 but they can hear me?
You have a microphone problem. Your voice is not detected by the gadget you are using.
Oct 08, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
Why is my motorola hx550 stuck in mute?
Ensure you have mute turned off on phone and headset.
Mark
Motorola Support
Aug 11, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
How can I pair the Motorola H550 to a second phone?
Did you mean an HX550? HX550 Pair connect with your phone . the H550 cannot be paired to more than one device.
Mark
Motorola Support
May 22, 2014 | Motorola Mobility H550 - Bluetooth Headset...
Hx550: Cant hear out of it
Connected to what phone? Have you unpaired and re-paired to your phone?
Mark
Motorola Support
Apr 10, 2014 | Motorola Mobility Hx550 Universal...
How to change language on hx550?
The HX550 does not have language settings you can only turn on/off the Voice Prompts, you can also check for the Voice prompts option by doing the steps below..Press and hold the Call button while turning on the
headset to turn these features on/off:
• Reset to factory default
Caution: This action erases all pairing information
stored in your headset.
• Caller ID
• Voice prompts
• Multipoint (two phone) connections
• WBS (Wide-band Audio) on/off
Follow the voice prompts to make changes to these
settings.
Note: Some features are phone/network dependent.
Mark
Motorola Support
https://forums.motorola.com/pages/home
Feb 13, 2014 | Motorola Mobility H730 Bluetooth Headset
Motorola HX550 works fine but will not charge at all
Quincy
Charge with Boom closed. Reset headset HX550 Reset to factory default then repair.
Mark
Motorola Support
Jan 08, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
Was working fine until now.
uninstall device and try to reinstall if this doesn't work go to www.n1wireless.com about 30 bucks
Dec 08, 2007 | Motorola Mobility H700 Wireless Headset
Radio Communications Logo
94 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
