Vaillant turbomax 242 1e no central heating, hot water works fine
Switching power off and on sometimes get the ch back on
5 Suggested Answers
  • 44 Answers
SOURCE: heating, but no hot water on a vaillant turbomax 28 combi
the problem is the diverter valve unit, source a corgi engineer to fit new one, cost for valve approx 80 quid +fitting
Kindly
Richie
Posted on Dec 16, 2008
mrgrzz
  • 88 Answers
SOURCE: Vaillant turbomax 28 constant hot water problem.
got your fix, its a calcium buildup in the heat exchanger, and more than likely the rest of the unit, you will need to flush the unit with about 4 gallons of vinegar, you will need to recirculate it for about 20 mins through the unit, then flush with clean water, hook it back up, it might take a couple of mins for it to run properly, but it will, I have had the same problem with Rinnai on demand hot water systems, and it worked like a charm, check the filter thats inline as well, make sure it isnt plugged, clean if needed, also if you dont have a soft water system inplace, you might want to think about buying one and having it installed, that will reduce this from happening again for alot longer period of time, hope that helps
Posted on Jan 20, 2009
  • 234 Answers
SOURCE: no hot water
My guess would be the unit mifired and need reset.
Posted on Mar 15, 2009
SOURCE: Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Posted on Apr 26, 2009
Intermittent hot water.Changed diverter valve,heat exchanger,fan, PCB. Vaillant turbomax 282e But still no hot water.
Sounds like you need a new Thermo coupler.
Could be as simple as a dirty pilot and needs cleaning but I suspect a thermo coupler.
Apr 14, 2016 | Water Water Heaters
Siemens rwb29 controller doesn't work properly. central heating comes up only when you select hot water, but not on its own
This happens to my rwb29 from time to time. You can try switching off the power to the controller for a couple of minutes with CH thermostat and CH programs set off. Or you can press the little reset button to the bottom right of the LCD screen. After 1 or 2 attempts these steps usually restore the independent control on my unit.
Nov 05, 2012 | Siemens RWB29
I need to power flash a vaillant boiler. can you please help. water goes hold and cold, sometime the heating stop but the water works and vice versa. i was told by an engineering that it needs power...
Hi
Although not a PC problem, i have had this same issue on my Vaillant Boiler, the problem you are describing is not a power flush problem, you need to clean out your exisiting diverter valve or purchase a new one
The diverter valve is repsonsible for either providing hot water or providing hot water to the central heating, when this valve gets stuck in between the symptoms you have described above occur
I would also not recommned that you do a power flush yourslef as you may end up damaging the boiler and its pump
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 23, 2010 | KDS Valiant 6380iPTD-01 Notebook
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
Apr 13, 2009 | Air Purifiers
No hot water
Mar 10, 2009 | Water Heaters
Jan 20, 2009 | Water Heaters
Clock on comi boiler
it may be the preheat setting on the boiler for the hot water circuit. do the radiators get hot when the boiler fires up with the time clock off ? if not then there is nothing to worry about if it is only on for a short time.
Jan 04, 2009 | Heating & Cooling
Heating, but no hot water on a vaillant turbomax 28 combi
Kindly
Richie
Dec 15, 2008 | Water Heaters
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
