Question about Hoover Candy& Dishwasher Door Latch 91670365 Genuine
Smeg DF6FAB door latch - Hoover Candy& Dishwasher Door Latch 91670365 Genuine
Door locked shut
Hi found myself in same situation. Press in latch and insert fingers upwards there is a grey plastic strip push this up with fingers and door should open. Note upward press needed where this catch meets front of machine so just slide fingers up from latch/handle. There's actually no need to take top off to enable this.
Dec 27, 2013 | Smeg STX2 Dishwashers
Power button will not power up DSI614
There is probably a swich on the door latch that is bad or out of alinment which wont allow it to start if not latched completly,that is what I have found on some.
Nov 29, 2013 | Smeg Dishwashers
Re: SMEG Integrated Dishwasher ST663. I'm having
usually a screw on the striker (the bit sticking out that goes into the door) it will be a slotted adjustment so just loosen (not remove) the screw and pull it out a mm or 2.
retighten and test.
Also, clean the seal. While your at it, the sump filters and spray arms.
Oct 18, 2013 | Dishwashers
Smeg dish washer wont stop even when the door is opened,
I never heard of a smeg DW but you can bet the door interlock is hung up in some way. Ususally its micro switches on the latch assy. Then again, could be a bad relay on the control board. I would dis connect the switch first and see what happens. The way I would do that is disconnect power at your circuit box and dis connect the switch, tape off the wire, latch the door and return power. Bet it doesn't run. Most likely the switch assy. Would help to know the right brand name tho...
Oct 16, 2013 | Smeg Dishwashers
Smeg df6fab
try Googling this or buying one on ebay or a white goods site?
Sep 21, 2013 | Dishwashers
Smeg washing machine stuck on pause
If the machine won't start then it will most likely be the door latch that is at fault.
Mar 12, 2012 | Smeg WDI12 Front Load Washer / Dryer
Door latch does not catch ,yet light goes on and turn table turns but does not heat. what part is needed and special tools?
Possibly door catch and/or door interlock switch may be damaged.
No special tools are required, maybe a torq 20 screwdriver.
Nov 04, 2010 | Smeg FME24X Microwave Oven
We have a smeg microwave and my wife slammed the door and now i doesnt work could it be the fuse?
If it's dead, it could be a fuse.
If it won't work properly, the door switch mounts or door hinges are out of alignment or broken.
The outside cover will have to be removed so the interaction can be observed between the hook-like door latches and the door switches as you open & close the door.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 02, 2008 | Smeg Microwave Ovens
Hoover Candy& Dishwasher Door Latch 91670365 Genuine Logo
27 people viewed this question
Top Hoover Dishwashers Experts
Gil Shultz
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
