Question about RTO 17" Mylar Fix Kit , 206289
Mylar fix kit - RTO 17" Mylar Fix Kit , 206289
How do I get the belt unstuck from the right side?
You will need to loosen up the right side one revolution, then run the belt at .5 revolution. Watch the belt then retighten the right side slowly until the belt stays in the center. Once its running in the center for at least 1 min without moving over more to right you can stop tightening.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Jul 17, 2015 | Proform Crosswalk Advanced 525x Front...
Di450 error codes cf033
Hey their... The code on your Hub450/550/470 is the toner density not being read. The drum must be removed u will find a sensor under the Mylar(mylar catches the toner wiped from the drum) that sensor is dirty and the Mylar is bad... :-D. PS u can perhaps repair the mylar with tape from the inside... Good luck
Dec 24, 2013 | Konica Minolta DiALTA Di200 Copier
Craftsman Incredi-Pull Weedwhacker Model 316.791860. Upon starting, I am unable to keep it running by use of the throttle. I have to let it run on idle which is very high, and trim without using the lever....
Some will say you just need to clean the carburetor but if you put a rebuild kit in it or a diaghram kit (cheaper) you will be cleaning it anyway. This points to a fuel delivery problem and it seems that the mylar fuel pump diaghram inside has stiffened and is no longer functional. Ethanol in the gas and time cause this problem. This usually causes lack of acceleration. A plain diaghram kit may fix this ill if nothing else is wrong. Get your Carb type and model (on carb body) and reference them here for rebuild or diaghram kits!
http://www.m-and-d.com/zama_carburetor.html
Aug 31, 2010 | Craftsman Garden
My minolta dialta copier has a c-of24 error code,
This code deals with the AIDC or Automatic Image Density Control failure. Most always this code is caused by toner collecting on top of the sensor. If you happen to know how to remove the Imaging Unit and then the Drum from the Imaging Unit then you could clean the sensor yourself. If not then I would recommend you call a service technician to correct the problem.
Basically what is happening is there is a thin mylar seal called the anti-spill mylar which is suppose to keep the toner off of the sensor. But these start to fail over time and allow toner to drop down onto the sensor which results in false readings and the C0F24 code. The mylar must either be replaced or what I do as a field fix is to reform the mylar back to it's like new shape so it seals. Then clean the sensor area of toner then re-install the drum and imaging unit back into the machine.
Good Luck and Thank You for using Fixya.
Aug 04, 2010 | Office Equipment & Supplies
Why is my Phaser 8400 leaving black smears on my printed pages and after running remove print smears, it doesn't correct the problem.
Have you looked at the roll in your maintenance kit? It may be dry in that area and not applying enough lubricant on the drum. Or you have some contaminant on the print head wiper blade or the mylar strip in the maintenance kit. Sounds like something is making contact with the drum causing your problem.
Mar 03, 2010 | Xerox Phaser 8400 Laser Printer
IP4200 leaks line of black ink on back of pages
There is a fix, design flaw as you say. You need a new ink absorber kit which includes a mylar strip so it won't happen again. What's happening is the waste ink from the purge assembly is pumped over to the center of the absorber pads and when it dries it stops the flow and it backs up thru the exit rollers.
Sep 30, 2009 | Office Equipment & Supplies
Xerox 5500 jaming at tray 3 and 2 constantly
There are mylar guide strips that get bent if paper is misloaded and the drawer is shut. Otherwise you need new paper feed rollers, which are part of the fuser maintenance kit.
Sep 28, 2009 | Xerox Phaser 5500N Laser Printer
When I print there there is a blck strak on the backside of printed sheet. How do I get rid of that?
The streak on the back is from ink coming up on your exit rollers. You need to have the machine taken apart, ink cleaned off the rollers, and a mylar shield put in to stop the ink from coming up on the rollers. Canon makes an absorber kit that includes the mylar.
Jul 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a Satellite A135-S2356 with the bios password. i have read bout this that can solve the problem. but the point is, i can't really understand with the explanation. what is mylar n JOPEN1? n how to...
Okay...mylar is a little flexible plastic or cloth-like piece (maybe even tape). JOPEN1 is a solder pad on the motherboard with two pins sticking up underneath this mylar. You need to remove the mylar from the JOPEN1 pad and, using a screwdriver, touch the two pins together for 30 seconds.
Jun 07, 2009 | Toshiba Satellite A135-S2276 Notebook
RTO 17" Mylar Fix Kit , 206289  Logo
20 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
