Question about Pioneer PD-F607 25-Disc CD Changer
The disc player skips the cd's
When my player, plays the cd's it skips on every cd as if the laser isn't good anymore, how can i fix this
Henry Kloss Model 88CD cd player skips. how to fix?
The laser assembly moves from the inside of the disk to the outside as it plays. You can try to clean the rails that the assembly moves on. If there is something stuck to it, it can cause the laser to have a hard time moving and cause skipping. try cleaning with cotton swab and isopropyl alcohol.
Dec 31, 2017 | The Audio Players & Recorders
Repairing coby cx-cd118 cd player
hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
cd player skips Google Search
Nov 27, 2017 | Coby Lands Phones
How to fix a mini system
Sounds like you need to clean the laser lense. I have a tip at http://www.fixya.com/support/r4119308-clean_lense_cd_or_dvd_player Let me know if this is helpful or you need anymore help.
hardrocko
Thanks for using FixYa
Feb 19, 2010 | Audio Players & Recorders
The cd player in my car will not play cd's anymore. even new cd's skip. a song will not play 3 seconds and then it skips out for minutes at a time.
try a laser lens cleaning CD it has small brushes on the bottom of it they go for 5 or 10 bucks it should work.
Feb 08, 2010 | 1999 Pontiac Firebird
CD skips in CD player
you can get a compatible laser unit on local electronics store.
Jan 17, 2010 | Audio Players & Recorders
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
Sony 5 disc automatic CD player model CPD 37 skipping badly on any cd
A replacement laser assembly that includes the turntable motor should fix that.
Nov 13, 2017 | Sony Audio Players & Recorders
New laserunit won't work
You seem confident enought to take it apart, have you tried cleaning the runners that the laser runs backward and forward on.
Some times they collect dirt/dust and the laser can't move smoothly so it jerks and skips.
Mar 13, 2008 | Denon DN-961FA CD Player
Cd player
Sounds like the laser slid is sticking. it's not the CD that's the issue, but solidified grease on the CD laser rail. The sled motor has to work harder to push the laser past the lump of grease but once it does the sound continues. Does it get better after you've played 3 or 4 cd's? Same time into a CD each time? If so it's easy to fix by cleaning the old grease off the laser rails and re-greasing.
Jan 23, 2008 | Audio Players & Recorders
Sony megastorage 300 cd changer
Hi There are many things that can cause your problem, I can tell you the most likely ones, but I recommend you don't take the unit apart, as the mech. in a 300 disk changer is complicated & delicate, and you may just cost yourself alot more money than getting it repaired. The symptoms you sescribe can be caused by failing laser pickup, dirty laser lense (especially if you've done home renvations with drywall), split drive gear that moves the laser on the sled rails, or even a hair or piece of dirt in the gear teeth of that same gear. The unit will play fine, until it hits the tooth where the debris are, then it skips, or jumps back a bit and starts again until it hits the same spot. Also..badly scratched or finger printed disks will cause that, but that is the first thing most people check. I wish it was something you could repair yourself, but my best advise is to take it to a reputable repair shop, and hope it is not a bad laser, as that is a fairly expensive repair. Hope this helps, Good Luck!
May 01, 2007 | Sony MegaStorage CDP-CX355 300-Disc CD...
Pioneer PD-F607 25-Disc CD Changer Logo
37 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
