Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Makes running water noise still from top part when finished run
When finished sounds from top of unit that water still running out and when I have just pipe under sink it sounds like it too
  • Hotpoint Master
  • 3,247 Answers
The sound of water flowing might be coming from the hard water regeneration unit which will operate sometimes after the wash cycle is complete to clean and regenarate the system. Make sure the salt levels in the container are adequate.
Posted on Feb 16, 2014
SOURCE:
Ac unit runs but the fan on top will stop and start turning and unit makes a noise. This is an older amana unit
I sounds as though the fan is getting ready to give up the ghost. Its kicking off on over loads..
Jul 13, 2011 | Heating & Cooling
Lately at certain times while running for days it makes a clanking noise(sounds like the fan) I spray water through the back of it with a water bottle and after 20 min the sound slowly go's away.It is...
This is normal, the noise you here is most likely ice build up on the condenser coils. when the outside temperature is under around 15c ice will build up on the condenser coils it then falls and hits the fan blades. this will also happen if the unit has been running for a while. there is no need to spay water into the unit as this can cause damage to the electrical components.
Jul 12, 2011 | Emerson Quiet Kool 12JW42K Air Conditioner
Whirlpool cabrio-buzzing noise when water runs
i think the problem that you have is one of the electric coils from the entrance valve from water. Check if there the vibration comes from there.
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Top drawer is ok. Bottom drawer makes lots of noise, but finishes the cycle ok
Can you describe the noise:
Water noise,
Mechanical sound noise.
Motor noise
Rattle noise
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
GE refridge temp control makes clicking noise
probably a few loose ends causing the rattle sounds it does it for most fridges.
May 11, 2009 | GE GTS22KBP Top Freezer Refrigerator
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
FAC124P1A1 window unit
It is probably freezing up and then thawing. Try cleaning the filters and running it at a higher temperature for a while. If it goes away then you are finished. If it does not go away you may need to bring it to a service center to have the refrigerant levels checked.
Jul 07, 2008 | Frigidaire FAC124 wall/Window Air...
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
55 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
