Question about Sigma Mouse
Mouse does not working - Sigma Mouse
Hi, I have USB keyboard and I installed PS/2 optic mouse to my PC. Mouse doesn't work .i have windows 7 ultimad 32 bit and MB DH55TC intel i am changin my optic mouse by roll mouse and again dont...
click start control panel view devices and printers you should see your mouse right click mouse you could open it and then select configuremy mouse or select settings then hardware make sure you have the correct mouse selected also right click on the mouse select properties to make sure you have the correct mouse right click on mouse you can troubleshoot this will activate the troubleshooting for you
hope this will help
Jul 23, 2011 | Computers & Internet
I have an Asus 1201N netbook and my mouse stopped working. Windows starts correctly and I can navigate through the Windows 7 Start panel with my keyboard but the mouse does not respond. What am I to...
Don't think it could be a mouse driver problem since you already said that it stopped working which meant that the mouse was in fact working before under Windows 7 on your netbook. Based on this, here are some suggestions to resolve your unresponsive mouse problem. Basically, you are trying to determine if the problem is due to the mouse or due to the netbook....
1. If you have a wireless mouse, did you try replacing its battery with a new battery?
If the wireless mouse now works with the new battery, your problem is resolved.
2. If you have another laptop, did you try moving the unresponsive mouse to try it there?
If the mouse also does not work on the other laptop, then suspect the mouse is faulty.
3. If you have another mouse, preferably a wired one, did you try it on your Asus 1201N?
If the replacement mouse works on the Asus 1201N, then suspect original mouse is faulty.
4. Finally, just an observartion, the Windows 7 mouse driver expects a Microsoft mouse and if you click on Control Panel > Mouse, the Mouse Properties window will say No Microsoft USB Mouse Detected but this should not prevent the use of any generic mouse.
Mar 28, 2011 | ASUS Eee PC 1000HE Netbook
Hi! My mouse doesn't work. The pc find the mouse but it doesn't work. It's a hp f2100a mouse.
Try using the mouse on another computer. Does the mouse work on this different computer? If not, then the mouse is probably broken. You can get a replacement mouse for very cheaply if you're not concerned about brand name, features, etc.
Here is a mouse on newegg.com: http://www.newegg.com/Product/Product.aspx?Item=N82E16826193049
Mar 01, 2011 | HP (F2100A) Mouse
My DEll mouse stops working when it feel like it. have to shut computer off and turn back on for mouse to light and work for awhile again. What"s wrong?wrong
Try your mouse in different USB ports, if it works well in the other ports then you know your original port is bad. If the mouse still acts up, then go ahead and try another usb mouse in the computer. If the 2nd mouse is working then you know the original mouse is bad. If the 2nd mouse is not working then you know that the usb ports on your motherboard are bad.
May 17, 2010 | Dell U0636 Mouse
98811 mouse wont work
The GE 98811 ergonomic Wireless mini mouse is a HID compliant mouse you will need to change the setting to use this mouse. This is what I would suggest:
Go to device manager
Go to the unknown device
Manually pick a driver
Mice and other pointing devices
***Change to a HID compliant mouse***
Then press the connect buttons on both pieces of hardware and the mouse should work
Hope this helps, it took me over two hours to get the mouse working. Very frustrating!!
Sep 03, 2009 | GE Wireless Optical Mouse
Logitech CE0560 keyboard and mouse; first keyboard
First put new batterys in the mouse and key board. if you don't have a tester use a flashlight. pen light. push the remote pickup. light will blinknext push key board button and the mouse next. then try it and see if it works.
sometimes do the mouse first, Then the key board
Aug 10, 2009 | Computers & Internet
Cordless access duo, mouse won't work
please go on control and look mouse setting and correct it. and also look battery of mouse, if not work there is hardwere fault. (nepal)
Jul 11, 2009 | Logitech Wireless Access Duo Optical...
My mouse not working (Idont know why)
Install the drivers for the mouse & recheck. Hope this helps.
Dec 24, 2008 | A4tech Wireless Optical Mouse rfsop-48
Mouse not working
Mouse not being detected in Windows 9x, ME, 2000, XP, or Vista. If the other mouse works in this computer attempt to use the mouse not working in another computer.
How to navigate Windows using a keyboard. Not only does this help users who do not have access to a mouse, it can also save you a great deal of time when working with text documents.
Autoexec.bat and config.sys help and instructions If the mouse drivers are not loaded properly you will not have the .... line is the name of the CD-ROM driver on the particular system we are working on.
Good Luck/Please dont for get to Vote.Thank You
Dec 19, 2007 | Computers & Internet
Re: wireless mouse and keyboard; mouse not detected
I bought the same combo from a parts house. The guy told me the mouse didn't work but didn't know why. I had the same problem. When I inspected the mouse closely, I found that the connect button on the bottom of the mouse had stuck underneath the housing...basically in the "connect position". When I freed it, the mouse worked and still works just fine. Hope this helps
May 11, 2007 | Impression Products Impression M1 Wireless...
Sigma Mouse Logo
35 people viewed this question
Top Sigma Computers & Internet Experts
David Payne
David Payne
Are you a Sigma Computer and Internet Expert? Answer questions, earn points and help others
