Question about Furniture
What colors does the 10 Spring Street Hinsdale 2-Door with Center Shelves Console Cabinet come in?
The Hinsdale cabinet you are talking about is only made in grey.
Posted on Feb 16, 2014
Change springs on garage door
It's is straight forward. Select a replacement spring with the same tension color as the original spring. The color is applied to one of the hooks. Above all thread the safety wire through the center of the spring.
Feb 02, 2014 | Stanley Hardware 730610 110 Lb Garage Door...
Door handle coming off
now you just need to buy another handle because the first one is not fixed well, it doen't cost a lot, but when you buy the handle you get free maintenance.
Mar 04, 2008 | GE GSS25JEMWW Side by Side
Refrigerator door not shutting correctly, not a good seal. could it be the little spring arm at the bottom?
check the gasket around the door,also make sure nothing is hitting on the shelves,if you have to remove some of the food,check the shelves and make sure they are back all the way,i've seen the bottom draws and shelves not in correctly,they stick out farther than they should hitting the door,remove the glass shelves that are on top of the draws and see if the door closes.let me know how you make out
Nov 28, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Controller does not turn on xbox
CAUSE Connection problems might be caused by one or more of the following factors:
Weak batteries or a weak Xbox 360 Rechargeable Battery Pack
Interference from another wireless device, such as a microwave oven, a cordless phone, or a wireless router
Metallic objects positioned between the console and the wireless controller, such as a chrome faceplate or metal dividers, shelves, or doors on an entertainment center cabinet
There are already four controllers connected to the console.
May 11, 2010 | Microsoft Xbox 360 Wireless Controller
Do i take the back off first
First unplug washer. There are two screw in the back of the console, left and right side, going down into the cabinet. Remove these screws, stand in front of the machine and rotate the console toward you and up and it will hinge backwards. Now there are 2 odd looking brass color clips on the left and right side going from the back into the cabinet, insert a flathead screwdriver into the clip on the cabinet side rotate screwdriver to the back of the washer and it will depress like a spring and come off. The door switch is plugged in from the back going to the cabinet. Unplug from the cabinet. Open the lid and rotate the whole cabinet toward you until it reaches a 45 degree angle. Watch carefully how the cabinet comes off to aid in reassembling. Pull the cabinet away from the washer. You will now have access to work on the washer. Good luck.
Thank you
Please rate this post
Jan 24, 2010 | Roper RTW4300SQ Top Load Washer
ROPER 4 CYCLE 2 SPEED DOES NOT AGITATE OR SPIN
Disconnect power should be a motor coupling broken you take off the cabinet, two phillips head screws left console bottom on back and right console bottom left on back and pull toward you and rollback the console two funny looking brass colored springs insert screwdriver into spring and push back toward back of washer and it will jump out. disconnect the lid swithch and lean cabinet out and looking down inside at front bottom slide out 2 inches to remove cabinet. then two black clips that hold pump on and then two screws and same except larger clips that hold motor on remove wiring harness and lift motor out and youwill see coupling either broken there or on transmission replace with part number 285852A from 1-877-262-1479 to put back on use hammer and 3/8 or 7/16 socket and extension and hit litely untillyou push metal center onto motor shaft then repeat for transmission side put rubber coupling on transmission side and line up motor and doall in reverse to put back together. tip on cabinet clips set in place and push down with heel of hand to snap into place
mike
May 31, 2009 | Roper RAX4233PQ Top Load Washer
Drum out of balance
There are a few things that can cause this issue.
1. The counter balance spring broke or the mounting hole for the spring rusted through.
2. One or more snubber pads may have come off.
3. The suspension springs may have stretched or broke.
Start by removing the shell as follows:
A.) Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
B.) With console lifted you will find a lid switch connector (white in color). Unplug the switch from the connector.
C.) There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
D.) Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
1.) The counter balance spring is located in the bottom rear. It should be attached between the cabinet and a bracket on the tub.
2.) Inspect snubber and corner pads. May be brown or white in color.
3.) Inspect suspension springs.
If you need further assistance, let me know
Regards,
reg501
Jun 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I have the roper Model: RTW4100SQ, and it would seem that a spring that keeps it balanced has come off and now sits to one side i am in need of knowning how to a)open top b)see and reatach spring or any...
To access internal components, REMOVE POWER, lift the console by one of three ways. 1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward. 2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw. 3. insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
There should be a counterbalance spring in the bottom rear of the machine. Sometimes the mounting hole in the frame will rust through..if so drill a hole next to old hole and reattach spring. Sometimes spring will rust and break..is so replace spring.
If you need further assistance let me know
Regards,
reg501
The FixYa Team
Jun 19, 2008 | Roper Washing Machines
How do I remove the cabinet on a Kenmore Model 11022882101 top loading washer?
You need to remove 2 screws in console. They might be in back, on ends or in front ends. If you can't see any, they are under the console end caps. To remove end caps, pry off by pulling caps towards outside from center part of cap. Pry toward you and towards outside. Then remove 2 screws and flip console up and back. Unplug connector to washer cabinet. Remove 2 gold colored clips by inserting straight screwdriver in them and prying back. Make not of their position first. Now tilt cabinet toward you and slide forward and off base.
To replace, tilt cabinet and slide under frame in front. Now lower cabinet on to frame, making sure cabinet is on frame on sides. Re-install clips by placing them in position and pushing down with palm of hand. Plug in connector, lower console and install screws.
Nov 21, 2007 | Washing Machines
Kenmore washing machine motor coupling
It goes between motor and transmission, underneath.
Furniture Logo
690 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
