Question about Acer Aspire E1-571-6650 Laptop
Start up menu not responding
I can't use start up menu, non responsive so unable to turn off laptop or use other functions
    Habit-Forming:
  • 152 Answers
Please disable unwanted softwares in msconfig by typing in run and restart.
Posted on Feb 17, 2014
3 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: slow laptop
Download C Cleaner and run it. Do a Defragmentation [start/programes/accessories/systemtools/defrag
Posted on Sep 27, 2007
frenzy19
  • 258 Answers
SOURCE: Touchpad is non-responsive
check the driver if its installed correctly in device manager
start>setings>control panel>system>hardware>device manager>look for the listings if you found the touchpad hardware is installed correctly then tell me the model of the laptop
Posted on Sep 20, 2008
Ntldr is missing
Try to reboot your computer and push F10 or F12 for boot menu. When you enter the boot menu find and select hard drive or C/: in the menu and continue to start the computer. If that doesn't work, your hard drive may be non-functional. I hope that helps.
Mar 16, 2014 | Acer Aspire 5315 Notebook
Only shows blue screen with cursor on every boot up, functions keys are non~responsive for SAFE MODE. Can u assist?
Have you tried shutting down and rebooting the computer while hold the X key? or the S key?
Try turning the notebook on while holding one or the other.
Jun 01, 2011 | Apple iBook G4 Mac Notebook
Hello, my cursor (touchpad) is non responsive. Thanks
I would check to see if it is turned off. On a Toshiba, you can press the Fn key and one of the special function keys to turn the touchpad on or off. There is an icon on the special function key to identify it.
May 08, 2011 | Toshiba Satellite P105-S6197 Laptop
Brother 165c clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide. clean unable 46
Error 46 on Brother printers The printer must be reset:
  • Press menu then*2864 within 2 seconds and press 80.
  • Keep pressing black/mono start button until screen displays 'purge count'.
  • Press 2783 to reset purge count.
  • Press stop/exit key
  • Press 99
  • The printer should return to normal
OR Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 12, 2011 | Brother DCP 165C Compact Color Inkjet...
Power on - Screen Black non responsive
Hi...
Look into getting the main power supply replaced
Check the web for someone near you
Apr 22, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
Laptop keys not functioning
Are they the same keys that are non responsive?? If so you probably need to have the keyboard replaced. Sometimes if the laptop overheats, the keys are damaged.
Apr 06, 2009 | HP Compaq Presario C700T
Non responsive
ok start your computer pressing f8 key and boot in safe mode then you can goto system tools and restore your computer to the time it was good earlier hope it works
Jan 27, 2009 | Toshiba Tecra A6-EZ6311 Notebook
Motorola RAZR V3 - keypad non responsive
sir it may be because accidentally the phone would have made contact with water... my advice is give the set to local service station and change the keypads... hope i have helped you.. thank you sir...
May 03, 2008 | Motorola Mobility RAZR V3
Acer Aspire E1-571-6650 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
