Question about ASUS Computers & Internet
Cant open disc tray
Its got a disc tray but no button to open it. how do I open it?
    Sergeant:
  • 239 Answers
Is there a pinhole on the front of the tray that allows you to trip the release with a paper clip ?
Posted on Feb 16, 2014
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
How do i open the disc tray on my laptop
Presuming you are talking about a CD-ROM drive, you should first check your manual for information on operating the drive. There are many ways drive trays may be opened. Sometimes there is a button on the laptop that has the standard symbol for CD eject on it that will open the cd tray. Sometimes, there is a small button on the cd-tray itself that when depressed will cause the tray to open after a small delay. This all presumes that you don't have a tray-less
CD drive, that is just a slot on the side of your laptop. If the CD tray is stuck, because of some problem, look for a small hole on the face of the CD tray. Take a straightened out paper clip and push it gently STRAIGHT into the hole until you feel it stop against a bar. Push just a little harder, and the tray should pop open. This latter procedure should only be used when all other methods have failed to open the CD tray.
Sep 04, 2014 | Toshiba Satellite Computers & Internet
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
The disc tray of my Xbox 360 console does not open
If the tray does not open when you press the eject button, try to manually open it. To do this:
  1. Unplug your Xbox console from the power source.
  2. Locate the manual release button on your Xbox console.
    For most Xbox consoles, the manual release button is located in a small pinhole to the left of the eject button under the disc tray.
    For some Xbox consoles, the manual release button is located under the disc tray. It can be under the "O" or the "B" in the word "XBOX" that appears on the tray.
  3. Insert a straightened paper clip or other small tool in the hole at an angle to the left. Gently push the paper clip to try to press the manual release button and partially open the disc tray. This may take several tries. Typically, a thin paper clip works better than a thick paper clip.
    If you insert the paperclip in the hole and find an obstacle, this indicates that your Xbox console's manual release button is located in a different area of the console. Look under the "O" or the "B" in the word "XBOX" that appears on the tray. If this is the case, insert the paperclip under the "O" as outlined in step C. If you find an obstacle, insert the paperclip under the letter "B”. The manual release button is located in one of these three locations.
  4. After the disc tray partially opens, pull the tray with your fingers to fully open the tray
Sep 22, 2009 | Microsoft Xbox 360 Console
Draw won,t open cant get my game out xbox360
  4. After the disc tray partially opens, pull the tray with your fingers to fully open the tray.
Hope this will help u.
Sep 22, 2009 | Microsoft Premium System for Xbox 360
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
The Disc Tray won't open!
press the button the it might go on if not take it back to the shop and say the disk tray wont open lol]
Jan 25, 2009 | Microsoft Xbox Console
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
