Question about AEG Washing Machines
Lavamat 60640 Machine not working , LED shows EH1. What does it means ?
I received an error EH1 in my AEG electrolux Lavamat L64850l washing machine, how can solve it?
Problems with the electrical power supply, the appliance remains in the alarm state until achieve conditions of work, and stabilizes the voltage and frequency, and the machine resets quenching (controller to the position "0").
Obviously there is a problem in the electrical network so my suggestion is to call your local electrician or try connect power supply from any other room.
Dado
May 04, 2015 | AEG Washing Machines
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Eh1,, what is this means?
EH1 Code = means that the supply to the machine is incorrect
Hope helps (reemmber to rate this answer).
May 12, 2011 | Washing Machines
AEG OKO LAVAMAT 72630 is showing E20. what does it mean?
Error code E-20 means drain problem. It means that the machine is not draining water correctly. Check the drain hose, to see if it is kinked or folded over. It could also be that the drain pump or drain hose are clogged. Drain the pump (check behind the little panel at the bottom right of the machine), first draining via the small emergency drain hose if you want to avoid a large puddle.
Also get the fluff filter removed and checked.If the filter is clogged then it will not let the water to get drained. The fluff filter is behind the little trapdoor below and to the right of the drum on the front of the machine. Open the door, unscrew the filter, and pull it out. It will be covered in smelly slimy multi-coloured fluff, which you need to remove. When you remove the filter, there is a good chance that a fair bit of water will come out at the same time, so, if you can place a very low bowl or similar below the filter before you unscrew it it will save you from having to mop the floor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 28, 2010 | AEG Lavamat 72640 Front Load Washer
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Windows 7 drivers for av3360
There aren't any, this was an XP machine.
Dec 31, 2009 | Averatec 3360-EH1 Notebook
END LED blinks 3 times
Worked out the problem - the heating element was burnt out. Very easy to replace.
Nov 13, 2008 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
