Question about JVC Televison & Video
How do I connect a LT-48N530A tv to an AV receiver
How do I connect them
2 Suggested Answers
Xtremeroofin
  • 67 Answers
SOURCE: tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Posted on Dec 20, 2008
LCD TV diplays blue screen on all inputs
Nothing on all inputs would suggest the Main AV board not processing signals, if all other functions such as volume, menu access, on and off operate normally the power supply board is probably functioning OK. Have a look at shop jimmy for an idea on price and availability for Mitsubishi LT-46144 Boards and spare parts:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 11, 2015 | Mitsubishi LT-46144 46 in. LCD HDTV
How to connect to tv to tv with component cables
In order to connect an AV receiver to a TV using component cables (Red & White) you will need to connect the component cables to an available AUDIO "OUTPUT" on the TV (red to red and white to white). Then the other end of this same cable will be connected to an available AUDIO "INPUT" on the AV receiver. The TV (via the menu or setup button) may have to be set to where the audio signal is output to a home theater and not to the TV speakers. Once connected, the AV receiver should then be set to the Audio input used in order to listen to what the TV is showing on screen.
Jan 02, 2014 | Audio Players & Recorders
No sound from AV receiver, sound only from TV
What brand/model is the receiver. Some have a function where you can select if the audio is passed through to the tv, or output from the receiver's speaker jacks.
Jul 14, 2013 | Televison & Video
/my screen is blue with video 1/auto showing on the top right hand corner, how do i sort the pro out.
i need more info?
The video1 is the input channel ,the auto is the sound and video system the tv uses to identify the signal(you have a multi system tv) {multi system (pal,ntsc,secam etc) if it is in auto mode you dont need to worry about it , the tv wil identify the system automaticaly and set the apropriate setings by itself.
You could press av on tv or on remote to switch between av1 /av2 /tv program etc, make sure the ant / dvd / cable etc is conected and on while selecting / pressing av button.
hope it works.
Apr 20, 2011 | Sansui DTV2760 27" TV
I cant get any sound I did the trouble shooting
Changing the Audio Output
To switch audio output from the internal TV speakers to a connected external sound system or headphones:
Press 1. MORE.
Press 2. 9 (AUDIO).
Press 3. until the Speakers option is displayed. The Speakers option will display only if an A/V receiver connection has been detected.
Press 4. to switch between TV and either AV Receiver or Headphones.
Check if the MUTE key is on.
• The TV's "Listen to:" setting may be set to SAP (analog program from the ANT input) but no SAP is being broadcast.
• Check that the Speakers option is set to TV to hear sound from the TV speakers. Possibly sound is being sent to one of the audio outputs for an A/V receiver or headphones.
• If using an A/V receiver, check that the Speakers option is set to AV Receiver to hear sound from the A/V receiver speakers.
Press and hold the POWER button on the control panel for 10 seconds to perform System Reset.
Mar 07, 2011 | Mitsubishi LT-40151 40 in. HDTV LCD TV
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
I want to connect my Pioneer XV-HTD520 receiver to Dish Net to provide music throughout my residence. I was connected to Direct TV until 1 week ago, everything worked fine but I was connected directly to...
I think we're both confused.
We need specific details when talking about AV gear because of the common interchangeable terminologies (but NOT fuctions) and cable types used by the audio and video sides.
Let's be specific about types of cables:
Coaxial Cable (for TV) = 300-ohm like an antenna conenction
Coaxial Digital Audio = RCA-style cable
Just because something fits doesn't mean it carries a compatible signal.
The closest thing I could find to describe the unique inclusion of a TV-style coax on the back is this:
http://forum.ecoustics.com/bbs/messages/3/84929.html
Is the HTD-540 capable of tuning TV stations (wall coax)? I doubt it.
The wall coax is for multiple TV channels, right? It's not the same as running a video coax from, say, a VCR on Channel 3, or is it?
Please clarify, if possible.
This statement, too, is puzzling, "but there is a TV >>> wo/output<<< jacks in the same cabinet ".
Common abbreviations I am familiar with would be w/output (WITH output) or w/o output (WITHOUT output). Which is this?
In either case, what is the relevance of output jacks on a TV? Unless you mean AUDIO output. Even so, why wash audio through a TV then send it via probably analog-stereo-only RCA cables to an audio-specializing device like the Pioneer?
Mar 01, 2010 | Audio Players & Recorders
How do I connect my video camera to the tv?
on the Tv rear panel look for the AV input/output, connect your yellow on yellow and white on white. That should work. oh then on the tv look for source button and it should be in the AV connection
good luck
Dec 14, 2009 | Samsung LT-P326W 32 in. HD-Ready LCD...
HTR-5930
To get audio from your TV through your AV receiver, please connect stereo audio cables from an available AV input on the rear of your receiver such as D-TV/LD or CBL/Sat. Then refer to your TV owner's manual for more information about audio output to an amplifier. You may have to turn off the internal TV speakers in order to get any output from the TV into the AV receiver.
Feb 17, 2008 | Yamaha HTR-5930 Receiver
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
