Question about JVC KW-AVX706 Car DVD Player
My computer is not reading cd's or dvd's - JVC KW-AVX706 Car DVD Player
I have dvd combo SONY CD-RW CRX300E but my problem is my drive can read cd but cannot read dvd please me to resolve this problem
Try the DVD-disk in some other computer, to see if the disk is the problem in _more_ than one computer.
Try some other DVD-disk in your computer, to see if your Sony drive can read _any_ DVD disks, i.e., if _NO_ disks can be read, then it's time to replace the drive.
Jun 20, 2011 | Computers & Internet
Can't read any CD or DVD
If you can read the CD/DVD disks in some other computer, then you need to replace the "dead" CD/DVD drive in your computer.
Apr 17, 2011 | Pioneer K16 DVD±R/RW & DVD-RAM Slim Writer...
My cd-rw/dvd rom burner is very successfuly to burn any kind of blank cd. The problem is : fail to read any kind of data from every common blank cd after burning. It's just only can read successfuly cd...
Have you taken a CD that you have burned to another computer, to see if the other computer can read the CD?
Rather than spending $50 to $75 to have a qualified computer technician try to trouble-shoot the problem, spend $40 to $50 to buy a brand-new CD/DVD reader/writer.
Aug 05, 2010 | ASUS QuieTrack CB-5216AG CD-RW/DVD-ROM...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Cd is not read
Try the CD disk in a different computer.
If it does not read, the CD disk is the problem.
Try a different CD in your computer.
If it does not read, the CD-drive is the problem.
Spend $40 to buy a new CD/DVD-writer, to replace the "dead" CD-drive.
Jan 05, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My lg dvd writer read both cd's and dvd's but later it did not
if the icon in not showing in the my computer. please check the power cable which is connect to the cd rom in side the cpu . but before doing this GO to your computer BIOS bu pressing DEL,or F10 or F2 depents on system manufacturing. there you see cd and make sure it is not diable .
Sep 29, 2009 | LG GSA-H55N DVD-RAM Burner
My acer aspire3680 laptop dvd writer cannot read dvd. they read only cd's.i have Dvd Decoder but still cannot read dvd's. why? plz send me answer my email address- sham_ptl@rediffmail .com
I have also the problem of yours but i have the solution and i do it with my pc now it read DVD/CD
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Jun 09, 2009 | Acer Computers & Internet
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
When I put a cd r in my burner then press burn selection then it
Try downloading a program called " RadarSync" it works like driver detective, might possibly help you out.
www.radarsync.com/
Dec 19, 2008 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
JVC KW-AVX706 Car DVD Player Logo
16 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
