Question about GE JVM1410 Microwave Oven
Ge jvm1410 mounting instructions - GE JVM1410 Microwave Oven
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 78 Answers
What about them?
Posted on Feb 18, 2014
Can you provide under cabinet mounting instructions for GE Microwave part WX4-A19?
To mount it under a cabinet, you have to have the under cabinet install kit; you'll find that here: Under Cabinet Mounting Kit WX4 A019 GE Appliances the kit does include instructions. You can't mount it without the kit.
Dec 12, 2015 | GE Microwave Ovens
GE Microwave model JVM1440BD operates but does not heat
On most occasions, it is magnetron. If you on your oven and hear an humming noise, that usually confirms magnetron problem.
You could see how to test magnetron
http://www.gallawa.com/microtech/mag_test.html
Let me know, once you test this.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 11, 2011 | GE JVM1410 Microwave Oven
I have jvm1430bd01 microwave and it stoped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ll
Apr 10, 2010 | GE JVM1410 Microwave Oven
Problems with GE JVM1410 Microwave Oven? when u turn it on it does not heat the food everything else works
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some questions to help you or someone you know troubleshoot it:
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
If not, then you probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If the inside light, cooling fan, and turntable are all coming on, then the problem is in the high voltage section, and then the next questions arise:
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
If there's no unusual noise, it may just be a bad connection at the magnetron.
Here are some links you or someone you know can use (in order given) for high voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's under magnetron warranty, GE will send you the magnetron to do it yourself. Call them at 888-239-6832.
If nothing else, you can save about $75 for a home visit by taking it to the shop yourself.
Jan 10, 2010 | GE JVM1410 Microwave Oven
I believe the magnetron just went out
Make a few phone calls and get the actual costs-then decide. You cant normally fix microwave ovens yourself though. Generally when the magnetron goes its time to buy a new micro unless its under warranty.
Oct 03, 2009 | GE JVM1410 Microwave Oven
Everything else works but will not heat anything. Clock works,glass plate turns,exhaust fan runs, lights work, just no heat.
Im assuming you dont have testing equipment. The best solution is to replace the capacitor and HV diode. Good chance that is the problem. If no heat still, replace the magnatron, definately will work correctly.(Sorry, to much to explaine otherwise relating to measurement and values). Let me know if still notright).
Sep 27, 2009 | GE JVM1410 Microwave Oven
JVM1440 BD - has a loud noise when I turn it on
Sounds like the "hub" for the turntable is worn. either that or the actual turntable motor. also insure the "plate" has a ring under it with wheels. sometimes I find those missing which in turn put far too much loud on the hub & motor, hence wearing them out pre-maturely.
you should be able to pull the hub out from inside the oven, if not. remove the filters below and if you twist just right you should see a small round device mounted with two tiny philips head screws, that's the turntable motor. It's usually the "hub" that wears though, so it's likely an easy fix. The most difficult part may be finding the new replacement part itself.
hope that helps,
good luck
Sep 26, 2009 | GE JVM1410 Microwave Oven
I need mounting instructions for the GE JVM1330. I have the brakets and the screws, but don't know where to drill the holes for mounting.
The installation instructions for this older model are no longer available for free download on the GE site, so you would have to order them or call GE customer service.
GE Customer Service is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jul 12, 2009 | GE JVM1330BW/WW Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1410WC001
Those are bogus voltages.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Jan 31, 2018 | GE JVM1410 Microwave Oven
GE JVM1410 Microwave Oven Logo
22 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
