Question about Buffalo Technology Buffalo DriveStation Axis Velocity HD-LXU3 3 TB External Hard Drive -
I-connect Lenovo emc not recognising my buffalo drive station velocity HD-lxu3. This is the 3Tb version and have read that the i-connect has problems with drives over 2Tb, so have partitioned it to 2 , 1.5Tb. Tried Exfat, and Ntfs, same result, light on drive just flicks off n on every 3 secs, and the drive isn't visible.
Crankstart
  • 696 Answers
SOURCE: My DEll PC runnig XP SP3 cannot
Yes the drive is compatible with XP. I have seen a slightly higher than normal # of problems with their 1TB models so this may just be a batch problem. My suggestion if there's nothing crucial on the drive is to return it an purchase a different brand.
If it's not returnable you'll have to settle for asking Buffalo for a replacement. If there's crucial data on it you will need the help of a recovery pro. In that case, comment back with your Country, State and City and I will point you to a nearby Recovery facility.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
SOURCE: Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
I think I have the answer, plug your cable in. If windows 7 shows the message unknown device don't remove the usb. instead turn the switch on the back of the external hard drive off for a few seconds then back on. Windows 7 should then for some unknown reason find the correct drivers and your buffalo hard drive will now work. This worked on mine.
Cliff
hotdesignerwear.com
Posted on Jul 26, 2010
lock123
  • 6831 Answers
SOURCE: Buffalo external hard drive not recognised on PC
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
  • 10406 Answers
SOURCE: When i connect Buffalo Mini
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
  • 10406 Answers
SOURCE: Everything worked fine until yesterday
* the USB cable
* the power-adapter
Testimonial: "THanks - I'll give it a go!"
My Buffalo 1TB mini station HD PCU2 started having some problems after connecting to my new laptop which is having windows8 os. At 1st i couldn't open some folders. It said to format. Did it thrice...
The windows 8 will not recognise the driver for this unit and this is a common problem with win8. Try to get Microsoft download for the correct driver for you machine
Aug 03, 2013 | Computers & Internet
Buffalo Ministation not flashing or recognized
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
Jul 22, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
Computer wont recognise external hdd
Follow these steps:
1. right click on My Computer
2.Click on manage
3.Click Disc Management
There you can see External hd (you can chose to activate or change drive letters and that will do the job)
Mar 29, 2013 | Buffalo Technology DriveStation HD-HC500U2...
Driver for HD-PNTU3
This drive showing as not supported for Linux as you mentioned.
Usually this is due to the board inside the enclosure.
You could crack open the case and mount the drive internally which would resolve this issue.
Otherwise you are down to trying to find a driver (not made for this model) that will be recognized by your system.
regards,
Mike
Sep 25, 2012 | Buffalo Technology Buffalo - Hdpnt500u3s -...
Buffalo external 1tb won't power up
Return the hard drive to the place of purchase, this is a manufacture defect.
May 12, 2012 | Buffalo Technology Buffalo DriveStation...
How to setup a wireless connection to HD-HG300LAN & Lenovo Laptop
Either connect it to the router ..and access it in the network ..or get into its settings ..and enable the wireless and connect to it wireless just like any other wireless connection ..
here are the manual and the quick set-up for it ..
You can even connect it directly to usb ..but will not have teh capability for wireless ..
The best way is to connect it to the router and access it from this point ..THis way you can access it from a cable LAN connection and from the router;s wireless one ..and even from its own wireless connection if it is enabled..
the general idea is that will share the information on it by cable and its own wireless ..and you will not depend on the internet connection unless you want to connect to it from another location .
http://www.retrevo.com/support/Buffalo-HD-HG300LAN-manual/id/419dj692/t/2/
In general the configuration is made just like in a router ..access it from the browser or by run command..
Dec 20, 2011 | Buffalo Technology Computers & Internet
My buffalo external hard disk can not read since yesterday, I/O device error. previoous was working fine. Do not know why? my Buffalo external hard disk model :HD-PX320U2
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Apr 13, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
My computer is failing to recognise it, therefore I cannot access all my files. My computer started by warning me that the external hard drive has malfunctioned, then it would say it cannot recognise it....
Too Bad.
do this
take apart the hard drive enclosure. and try to connect the hard drive direct to the computer, if you can't do this, try with another adapter, if this fails your HD is Die. sorry
Feb 22, 2010 | Buffalo Technology DriveStation HD-HC500U2...
Buffalo linkstation 400
I mistyped. It should read....."how do I get into the box WITHOUT destroying it all." Still need a fix for this.
Aug 28, 2008 | Buffalo Technology HD-HG400LAN...
Buffalo Technology Buffalo DriveStation Axis Velocity HD-LXU3 3 TB External Hard Drive - Logo
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
