Question about Miele Novotronic T230C Electric Dryer
Miele t 234c keeps blowing thermostat - Miele Novotronic T230C Electric Dryer
My miele drying machine shut off after a few use then wait for a few days to work again suspect that it got moisture inside.what to do
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Mar 01, 2015 | Miele Dryers
Miele tumble dryer
Maybe time to replace it. How can it be too much detergent? That would have the effect of lubricating the seals!
Mar 04, 2014 | Dryers
I have a Bryant 310AAV furnace that is not blowing cold air. Any suggestions?
I have a 234c-4pw boiler that has been worked on by a plumbing company they have replaced zone valves and replaced the 3 speed pump to a single speed pump now it wont even push the air out of the system
Sep 12, 2013 | Bryant Heating & Cooling
Dryer keeps stopping cycle
The most common cause of the error is lack of airflow. Check the exhaust output and see if it is restricted, you may have to check the venting in the building and unhook the dryer from it to check and see. If it runs unhooked from the exhaust system then it is a venting issue. IT could also be plugged lint screen, loose fan motor or obstructed fan. If it is not any of those then it is the thermal sensor or thermostat that is bad.
Jul 09, 2013 | Miele Dryers
Miele t4262c not heating up
The thermostat is jammed-located behind the rear central panel,
Remove the 4 screws and prise of panel to reveal the thermostatic switch which is held in by one screw and the heat element that is held in by metal tabs. Both these items have 2 wires attached. Unscrew thermostat and chuck it on the floor a few times to juggle and reset. Really. Replace and enjoy the heat back !
Sep 12, 2012 | Miele Dryers
Can't seem to get heat My Miele dryer is 3 years old
hi,
if your condenser is blocked the airflow is restricted and can cause the thermostat at the rear of the unit behind the cover to create an open circuit. you would need to remove the rear cover and check with an electrical meter to see if the thermostat has resistance. it looks like a small round disc with a wire going to each side of it. you can order a replacement thermostat from Miele but remember to also clen your condenser before running it again.
Hope this helps.
May 30, 2010 | Miele T9800 Electric Dryer
Thermostat keeps blowing fuses
There is a short in one of the thermostat wires. The fuse is triggered on the low voltage side of the unit. Replace the wires.
Feb 08, 2010 | Coleman Heating & Cooling
Miele T9820 runs except no heat
you have probably blown your thermostat especially if your condenser is blocked and hasn't been cleaned. this causes the unit to over heat and to protect the heater element the thermostat blows and breaks the electrical circuit. you will need a Miele service tech or service agent to repair the unit.
Sep 29, 2009 | Miele T9820 Gas Dryer
Open Questions:
See all Miele Novotronic T230C Electric Dryer Questions
Miele Novotronic T230C Electric Dryer Logo
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
