Question about Wildon Home Regency Havana 300 Thread Count Reversible Duvet / Sham Set Color: Wine / Charcoal, Size: King"
What are the colors this set is available in?
    New Friend:
This set is available in a wide variety of colors:
What are the colors this set is available in? - 002ecf3f-4777-4d51-a196-1ddf3c0cfeb2.png
Posted on Feb 16, 2014
Tv does not have green color, the grass color is purple
Find out which board on your set is responsible for the color of the scenes -info available on google search.
Get the part number off of the board and use that number plus the sets model number to do a search on ebay. Often you find sets and parts for them on the cheap.
Sep 10, 2015 | Televison & Video
My LGs color changed the opposite color
  1. HArd to know if your issue is a problem or a settings issue. Reference the monitor manufacturer's instructions to adjust the brightness and contrast settings using the Menu. If available, you may also need to adjust the color balance and temperature settings.
Feb 09, 2015 | Televison & Video
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Color need to be reset
Reset the TV to factory settings. The option will be available under General Settings.
Aug 19, 2012 | Westinghouse Televison & Video
Picture is OK but has no color
To other expert--not a camera here--to asker of this question:
First look to see if color when a DVD etc is run via the rear audio and video jacks.
This will narrow down where problem is.
Try unplugging set and or a box if used.
no color if in the set is the main board which may or may not be available for this brand.
You can Google the model number with "parts" to see what is available and what the boards may sell for--main is of course the most expensive board in the set............
May 30, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Mitsubishi WS-65611 has a blurred image with the colors creating almost a double image. was told it might be a color wheel. Should i order a new one? Best Buy said it would be a $150 house call to...
The model number you have posted does not have a color wheel at all.
If it is WS-65611 go into the customer menu and select convergence--if it is 3d and will not adjust there--you have a convergence problem.
I HAVE AVAILABLE START TO FINISH, STEP BY STEP INSTRUCTIONS for replacing this part in this set--available here for free.
If someone told you it is a color wheel and you have the correct model number here posted--they are not very smart--this model does not have a color wheel and the later Mitsubishi sets that did have one--they do not sell the color wheel for them.
If you want the instructions let me know and I will post them here for you. I have repaired hundreds of these sets and the instructions are based on actual experience doing this repair.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi WS-65611 65" Rear Projection...
I have Windows XP with Rx580 Epson Printer and need black print
Get one of the resetters for the ink cartridges (might not be easily available in the US - I know they are available in Thailand. Reset (electronic resetting of the internal chip) the color cartridges to "full" and then set the printer to "BLACK ONLY". Don't print in color and you can print black. Alternately get a set of refillable cartridges (I got a set again in Thailand for about $20 for the set of 6) fill the black and ignore the others. it will ONLY print BLACK
Mar 31, 2009 | Epson Stylus RX580 InkJet Photo Printer
Picture color is off
Google or lookup in windows help for
setting the color profile of my camera
setting the color profile of my screen
setting the color profile of my printer.
color profiles are methods to determine the disparate ways many items use to display color, by setting the correct color profiles in you pc's hardware items you can view images on the camera, screen or in print and have them look the same. it is possible that your display drivers do not have an appropriate profile for the fuji finepix, icc icm profile files are usually available from the makers, but you have to know which one,ma nd how to install it.
Sep 24, 2006 | Fuji FinePix 2650 Digital Camera
Wildon Home Regency Havana 300 Thread Count Reversible Duvet / Sham Set Color: Wine / Charcoal, Size: King" Logo
85 people viewed this question
Top Wildon Home Home Experts
john h
Tom Chichester
Are you a Wildon Home Home Expert? Answer questions, earn points and help others
