Question about Roland GW8 Keyboard Arranger
Window lights up but no display - Roland GW8 Keyboard Arranger
    Top Expert:
  • Roland Master
  • 3,113 Answers
Your Betsy info will be from Roland Support. Here's the link-
Roland Company Contact Us Contact Us
Posted on Sep 04, 2016
Senpera 2 when plugged into amp lights up but no display screen shows
Contact Peavey toll free at 877-732-8391 or by email at,
Dec 31, 2014 | Peavey Electronics Peavey Sanpera 2
Where would I go to get a back light for a Technics PR-305 Liquid crystal display
It could be the light, or it could be the inverter that powers the backlight. Try asking this guy:
Jun 09, 2014 | Universal MCU Extension 4 x 4 16-Key...
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS
9. Press the PLAY button.
Apr 16, 2014 | Tascam DP 008 Digital Portastudio
Hi , I wonder if you could shed some light on a problem my son has with his behringer pmh3000 amp. With the digital effects set to any number it constantly reverts to 1. Also when effects are turned on...
You say lights flash? There are a lot of LED's on the unit and there are displays. Depending on what you mean by "lights" sends us on a whole different path. Remeber the effects ADD to the noise as they add into the buss to the amps. You should have the Effect to MAIN knobs not too high... say 12 o'clock. Same for the effect send knobs for the channels. If all the LED's flash, better stop using the unit as there is a power supply problem and damage will occur.
Please read my tip on here about the hazard of Channel A output when using Speakon to 1/4 inch speaker cables or adapters. The SHELL or SLEEVE of channel A cable is the HOT one, NOT the tip so never let that shell touch or connect to ground. The effect window when first powered should display a zero, not one... If it displays 1 at first, unit needs to be taken for repair as there is a defect.
Connect ALL interconnected equipment to the same receptacle or power conditioner source. Pro's run extension cord back to mixer if they have other stuff on stage. The speaker cables should connect to NOTHING other than speakers... do NOT try to tap off the daisy chain outputs of speakers for anything other than speakers. Use balanced lines and isolating DI boxes to avoid ground loops. Make sure to only poower this from a grounded receptacle.
Apr 16, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Hi theres nothing showing up on the blue screen
If sound is going through this, then the display is the only problem. Some of these use a gas-discharge display and when cold or haven't been used for a while, they don't start right away.
If this might be the problem you can try helping the display ionize by shining a bright, perferably Halogen light into the window of the display. Let unit warm up and set awhileto see if display will come on.
Jan 06, 2011 | Peavey 16FX 16 Channel Mixer
Lcd display is what seem to be to bright hard to read black info .or the black symbols are very light hard to read with bright orange lighted display thanks Mark
You don't say what device this is on, HOWEVER most thngs have a "contrast" control that will adjust the visibility.
Sometimes they call this a viewing angle control and sometimes it is a small shaft from the back of a unit, OTHER times it is a setting available through a menu... if you can read the display enough to find it...
Oct 12, 2010 | Music
No display light on my casio ctk 496 every thing else works
Sorry, but many of the low end keyboards do NOT have backlights. This is especially true of those that have the capability of running off batteries like the CTK-496.
The display in this is a reflectance type that needs ambient lighting to view.
Mar 13, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Window display not functioning
You need to use a transformer type voltage convertor.
DO NOT use the type for converting 220 down to 120 for hair driers.
The voltage should NOT be a problem as usually these will operate down to 100 volts. If the keyboard is sounding correctely, that would indicate there is NOT a problem with voltage.
It is LIKELY that the connections to the LCD were damaged in shipping. There are many, many connections to the glass assembly and if dislodged will have lines across the display.
Repairing this is usually not something one can do unless very experience in electronics.
Mar 12, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Roland GW8 Keyboard Arranger Logo
29 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
