Question about LG Computers & Internet
LG NAS N1R2D installatie - LG Computers & Internet
NAS Disconnecting from Network
I hope the brothers who has a program Printer Definition "murtec mfx 2010" Windows 7 download link here Vlada graciously
Mar 10, 2014 | LaCie d2 Network v.2 - 3TB
Does not detect
Try downloading the Initialize/Reset ISO from LG first.
http://www.lg.com/us/support/product-help/CT10000002-CT30000780-1338578750719
Then, after running it, try to update the firmware to the latest version. Post back how it works out.
Jan 05, 2014 | LG Electronics NAS Servers N1T1DD1B N1T1 -...
Reset n1t1
Download the LG NAS Initialization software and burn the image to a CD or DVD. Put the disk into the LG and turn it off. Hold down the backup button and while continuing to hold the backup button you turn it on. Continue to hold both buttons for about ten seconds. Let go.
Nov 05, 2013 | LG 1 TB 1Bay N1T1 Network Storage with DVD...
Booting fail
hola engo el mismo problema de booting fail he optenido ecte nas en ebay con dos discos de 1tb y este no funciona he echo casi todos los pasos del manual de instalacion precionando el boton de encendido mientras preciono el boton de flecha derecho e izquierdo entra en modo netboot y hay logro configurar la ip en el siguiente paso con el programa nas etector me dice que actualice el firware,pero no tengo forma de hacerlo ya que para ello tengo que tener acceso al nas y no puedo de ninguna forma gracias a quien ayude a solucional este fallo
Feb 01, 2013 | LG N2R1 - NAS server (S7636797) Network...
Need parts for an LG N2B1d
Thank you for asking me directly to help you with your problem. However, either the question you are asking is not within my area of expertise (I am an automotive repair technician), or the question is incomplete and does not contain enough information for me to help you.
Jan 08, 2012 | LG N2B1D Network Storage Server
What is nas
network attached storage server using bsd.used for backup
www.nas.org
Feb 05, 2011 | Microsoft Windows XP Professional for PC
How do i reset LG N2B1DD2 to factory default?
This is for some reason called "Enclosure mode" on this LG nas.
Read manual page 18 (find it on google) and it will reset to default
Jan 26, 2011 | LG N2B1DD2 2TB Super Multi NAS with Bluray...
My Belkin Home Base F5L049 isn't recognising my external hard drives that have their own power supply. Seems to be working fine with USB powered hard drives. How do I get it to recognise my powered...
I am having similar problems with my HomeBase. I have 3 x 1Tb Seagate external USB2.0 NTFS drives (FreeAgent) connected. The aim is to have my digital TV, LG set-top box, Apple TV, PC and Laptop all access the files and capacity offered by the NAS option.
They work fine in 'single user network USB' mode, but are very flaky / non-existant in 'NAS, multi-user' mode. There are times when the HomeBase is restarted and recognises one or more of the drives in NAS mode, but mostly they are not recognised. On the back of the unit, you can see the LED next to the USB port leading to the drives initially stay lit, but then flashes for 10-15 seconds and then goes out.
As I want the hard disks available to multiple devices I need to use the NAS setting.
Did you try to set the drives into 'Network USB mode' rather than NAS mode. Does that help?
Did anyone have a solution to the problem? Unfortunately Belkin technical support have not been very useful yet...
Thanks
Mark
Dec 26, 2010 | Belkin Home Base WirelessN Access Point...
Tritton T-NAS 120GB Vista connectivity
did you ever have any luck connecting to your nas
Mar 09, 2008 | Tritton Technology T-NAS 120GB (trinas120)...
Computers & Internet Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
