Samsung 931bw my lcd is white blank
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have Samsung LCD 931BW and it seems to be in
Not likely to be sleeping but the failure in the power supply due to bad caps (bulging, leaking), very common in ALL LCD monitors. If you are going to DIY repair, please read below and look through my albums so you will know what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 21, 2010
White screen
"White screen" on Samsung LED TV - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
More results from www.cnet.com
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
Lcd screen blank white
Dear Amit,
If your device is showing blank LCD that mean there is hardware problem, show some technician to fix this.
Jul 17, 2013 | Samsung GT- C3222
Samsung 19 "LCD SyncMaster 931BW ...Colored
Hook a spare monitor to the computer to insure there is no problem, if everything checks out okay,the problem is in the Samsung screen display and is not cost effective to repair, far cheaper to buy new. But if both screens show the same problem, it is a video graphics card issue in the computer, one further thing if the video cord is detachable from both ends, sub another cord.
Feb 04, 2011 | Samsung 19" LCD Syncmaster 931BW Monitor
My Synchmaster 931BW LCD takes a long time to turn on and it appears to be increase everytime I turn it off, once I turn on my computer the monitor light keeps flashing but does not display image, after a...
Typical symptom of dying power supply due to bad caps with domed tops as you can see in my SAMSUNG albums. Make sure to replace them in a set.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 25, 2011 | Samsung 19" LCD Syncmaster 931BW Monitor
My Samsung SyncMaster 931BW monitor has been working fine for me. It was working fine last night turn it back on this morning and the screen is just black. Reset computer checked the cords and power outlet...
Try it with another PC to make sure is is not the PC video card problem, also chek the cable. If it still does not work, then you will have to open it up.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Oct 05, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
Monitor don't start with start of PC.
Replace the electrolytic capacitors on the power supply board.
Some will have bulged, but it'll be a good idea to replace all of them
May 15, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
I have Samsung LCD 931BW and it seems to be in sleep mode but cant get out of it pressing buttons ...al rewired cables, another computer
Apr 21, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
CHECK SIGNAL CABLE
MEANS THERE I SN O DISPLAY SIGNAL FROM YOUR PC..........PROBLEM IS WITH YOUR PC NOT WITH LCD
Mar 09, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
