Could not find the main class: Program will exit
    Problem Solver:
  • 7 Answers
Are you trying to access a program that you downloaded?
Are you trying to program something?
This is an error that is encountered when a program is started but the system cannot find the main class (The first step to starting the program which controls the whole flow of the program)
If it is something you downloaded from a rookie developer, or something you programmed yourself take a look at your main function, it is probably declared improperly. Google the specific language you are using to see how it is supposed to be declared.
If it is a mainstream something you are trying to install and run something somewhere corrupted. Try to re-download and reinstall. If that doesn't work it is possible something in your registry is corrupted... unlikely, but possible.
Posted on Apr 28, 2014
Could not find the main class: Program will exit in oracle 11g
That's a Java software error
When running a Java application, if is not possible to find the class with main declaration due to missing main method, class path location or others then the application will not start
Feb 16, 2014 | Computers & Internet
I have a 2004 GMC Envoy with 6 cyl engine. Both remote keyless entry went dead at same time and now I can't unlock the back hatch door. I had to release it manually but the sensor keeps locking it back....
Take it an have it check at a qualified repair shop for DTC'S - diagnostic trouble codes . Could have problem with the liftgate/endgate module. Don't try guessing to find a repair .
The keyless entry system has the following main components:
• The transmitters
• The endgate module (EGM) (XUV only)
• The liftgate module (LGM) (Except XUV)
When you press a button on a transmitter, the transmitter sends a signal to the liftgate module. The module interprets the signal and activates the requested function via a class 2 message over the serial data line.
Do you know what class 2 serial data communication network is ?
You need a scan tool to program the remotes .
Program All Key Fobs
To complete this programming operation, all keyless entry transmitters associated with the vehicle must be available for programming. Once placed into program mode, all previously programmed transmitters will be erased from memory upon the receipt of the programming signal from the first transmitter.
Close the lift gate.
Ignition ON, access the scan tool Liftgate Module Setup menu and select Program All Key Fobs.
Follow the the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
As each transmitter is successfully programmed, the scan tool will show how many transmitters have been placed into memory.
When all transmitters are programmed, exit the program mode by selecting "Stop" on the scan tool. The vehicle will not respond to the transmitters until the program mode is exited.
Operate the transmitter functions in order to verify correct system operation.
012 GM Class II Communications
Jul 25, 2017 | GMC Envoy Cars & Trucks
Java error says... could not find the main class: com.sun.servicetag.installer program will exit How can I fix this?
goto --> www.java.com and re-install java runtime... you should be okay after that...
If you need further help, reach me via phone at https://www.6ya.com/expert/jim_8aa10a90cbbc76ff
Mar 10, 2011 | Computers & Internet
Can you give a sample running C# program?
// Hello1.cs public class Hello1 { public static void Main() { System.Console.WriteLine("Hello, World!"); } }
Mar 01, 2011 | Computers & Internet
Wirte a pogram in java using for loop,that will print out the first 1 numbers of a fibonacii series that is:1 1 2 3 5 13 21 34 55
package com.gpt;
import javax.swing.JOptionPane;
This program computes Fibonacci numbers using a recursive
method.
public class Fibonacci
public static void main(String[] args)
String input = JOptionPane.showInputDialog("Enter n: ");
int n = Integer.parseInt(input);
for (int i = 1; i {
int f = fib(i);
System.out.println("fib(" + i + ") = " + f);
System.exit(0);
Computes a Fibonacci number.
@param n an integer
@return the nth Fibonacci number
public static int fib(int n)
if (n return 1;
else
return fib(n - 1) + fib(n - 2);
Feb 24, 2011 | Sun Java Programming Language (cdj-275)
Frostwire download problem
CLICK HERE
If you have further problems, please do not hesitate to contact me on Skype (Skype Username: fixya-support)
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 23, 2009 | Computers & Internet
Java is not working
Hello there :
first you are going to want to ensure that your your current version of java is installed correctly and is not corrupted and if it needs to be reinstalled
download the latest java version and reinstall this . www.java.com
this should be able to take care of the problem that you are having ok?
best regards michael
Aug 23, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Jnlp code for the java program
From command prompt: You can also launch an application from a command prompt by typing javaws jnlp_url where jnlp_url is a url to the jnlp file of the application. Go to Start > Run > type "cmd". A command prompt window will appear. Type "javaws url_of_jnlp"
May 28, 2009 | Microsoft Office Word 2007 Upgrade Version...
How to compute a class average using arrays
hi, here is the program #include<stdio.h> #include<conio.h> void main() { int class[30],i; float sum=0,avg=0; printf("enter marks"); for(i-0;i<30;i++) scanf("%d",&class[i]); for(i-0;i<30;i++)
sum+=class[i]; avg=sum/30; printf("%f",avg); getch(); }
May 08, 2009 | Microsoft Computers & Internet
Rename a folder in c drive using java code
import java.io.*;
public class RenameFileOrDir{
public static void main(String[] args) throws IOException{
BufferedReader in = new BufferedReader(new InputStreamReader(System.in));
System.out.print("Please enter the file or directory
name which has to be Renamed : ");
String old_name = in.readLine();
File oldfile = new File(old_name);
if(!oldfile.exists())
System.out.println("File or directory does not exist.");
System.exit(0);
System.out.print("please enter the new file or directory name : ");
String new_name = in.readLine();
File newfile = new File(new_name);
System.out.println("Old File or directory name : "+ oldfile);
System.out.println("New File or directory name : "+ newfile);
boolean Rename = oldfile.renameTo(newfile);
if(!Rename)
System.out.println("File or directory does not rename successfully.");
System.exit(0);
else {
System.out.println("File or directory rename is successfully.");
Mar 30, 2009 | Sun Java Programming Language (cdj-275)
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
