Question about Acer Aspire Computers & Internet
My Acer Aspire 1410 will not power up although the fan, the Caps lock and Num lock lights come on briefly. How can I fix this, please?
    Habit-Forming:
  • 152 Answers
Please check in safemode else check the VGA cable.
Posted on Feb 17, 2014
tom19511
  • 1601 Answers
SOURCE: CAPS LOCK PROBLEM!!! URGENT HELP NEEDED!!!!
On some keyboards, there's a hidden 'feature' where if you hit CAPS LOCK and Shift at the same time, everything works backwards, until you hit that combo again.
Try this and let me know if it pertains to you...
Posted on Dec 29, 2007
SOURCE: Dell Inspiron 6400 won't power up...
Most probably the seating of the processor on the motherboard is not proper
check this site and mount the processor properly
http://support.dell.com/support/edocs/systems/ins6400/en/sm/cpu.htm#wp1084976
Posted on Feb 02, 2009
hothawk
  • 174 Answers
SOURCE: Laptop fails to boot up. Caps lock & Num lock
The problem may be your display LCD is not working - check that hard disk is running - when you touch you may feel a running sensation -
There are many problems It can be motherboard problem or any of the devices is not working ie.. hard disk PCMCIA Cards i suggest you should an expertize check.................
Posted on Jan 20, 2010
parrotheadpc
  • 2600 Answers
SOURCE: NUM lOCK SEEMS TO BE STUCK ON MY aCER aSPIRE
Try the "Fn" key plus the Num Lock key
Posted on Jun 07, 2010
  • 2567 Answers
SOURCE: when i press power bottom
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced
Posted on Sep 20, 2010
How do I know if my caps lock is on on my Acer Aspire?
When the CAPs lock is on the CAPs LED will light up, the same also applies for the Num lock.
Apr 09, 2013 | Acer Aspire 5750 15.6 inch Laptop Intel...
Hi I have acer laptop which as stopped working no boot up nothing just turn it on and fans start then keep getting bleeps any help please
Try to boot it up in Safe Mode and see if you can use System Restore to restore your computer to a earlier time when it was working correctly. Turn the computer on and when it try to boot up keep on pressing F8 on your keyboard to force the computer into Boot Options.
May 28, 2010 | Acer Aspire One PC Notebook
Power light comes on but not working
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 27, 2010 | Computers & Internet
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
The status lights for my acer aspire 5720z laptop are not working
This problem occur when your laptop for example is drop. To fix it go to Computer Shop or Repair Center and let them the one to fix your laptop. I'm sure it back to normal.
Nov 22, 2009 | Acer Aspire 5720 Notebook
Blank screen...no keys working
Hi
is the acer still covered by the warranty? you can get it repaired for free if it is, its a common fault with these, my friend over here in finland has one of those and it did the same thing, he got it replaced / fixed for free since it was under warranty. get yours fixed also.
May 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
You broke it! Try re-installing OS software, hoping you still have the CD disk.
May 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Aspire RC 500 - Acer w'less k'board & mouse packed up battery o.k
have you tried going into BIOS and setting Num Lock ON in startup? Do the Num Lock / Caps Lock and Scroll Lock flash when you boot up?
Check the pins if using PS/2 or is it a USB keyboard?
Cheers
Tim
Dec 12, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
