Question about 1992 Chevrolet Camaro Z28 5.0L Oxygen Sensor
How can I change the oxigen sensor on my Camaro 1992 V8 ?
The car feels no power and the engine light goes pretty often?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 102 Answers
Sounds like gas related fuel filter is blogged or the pump is weak.If not than has to be electrical. witch can be a night mare. but when the engine light is on have your local parts store put a diagnostic pc on it . Most of them do this for free! good luck
Posted on Feb 16, 2014
  • Charlie Diaz
    Charlie Diaz Feb 18, 2014
    I will change today all for new parts
  • Charlie Diaz
    Thank you
  • 3 Answers
How many miles? What parts have been changed? Is the loss of power only at low rpm or when taking off?
Have you checked your air cleaner? Spark plugs? Go over all your basics
That could be a vacuum leak. Spray carb cleaner at gaskets and hoses. If the rpms go up, there's your problem.
Without more info no one will be able to help you.
Posted on Aug 30, 2014
Install the knock sensor on Camaro 92 V8
The knock sensor is on the passenger side of the engine, down below the exhaust manifold, and threads into the water jacket. Use the proper sized socket to remove. You may lose some coolant, so either drain some coolant first, or be quick getting the new one into the block. Not too hard to replace. It is about the size of a silver dollar and silver in color.
Apr 13, 2014 | 1992 Chevrolet Camaro
My 2001 Camaro idles really rough, loses power when accelerating, and the check engine light starts flashing.
ALUMINUM V8 CAMAROS HAVE 3 PROBLEMS
1 VACCUUM LEAKS ie HOSE TO THE pcv deteriorates
2 MASS AIR FLOW / hard to diagnos sometimes
3 COLLANT temp sensor, ie starts fine cold, crappy when warm
Oct 10, 2012 | 2001 Chevrolet Camaro
WE OWN 92 CAMARO RS 25TH EDITION IT WONT START ITS GOT FIRE POWER AND SPARK SO NOW WHAT ITS DRIVE ME CRAZY WHAT TO DO. WE CHECK THE SPARK PLUG AND BATTERY AND ITS GOT GAS BUT IT WONT START WHAT DO U THINK...
92 Camaro, V8 5.7 multi port, new pump, good preasure. runs when primed, wont start without prime. After sitting a few minutes, engine fires wont start. How to check EGR Valve and what does it do?
Feb 15, 2011 | 1992 Chevrolet Camaro
Im getting to much fuel my 1992 camaro rs 5.0L 305 v8 TBI. its running real rich. ive replaced the cooliant temp sensor, throttle position sensor, fuel pressure regulator,spark plug and wires, distributor...
The precatayltic O2 sensors or sensor may by malfunctioning.These are the O2 sensors that tells the ecm to adjust the air fuel ratio according to how much oxygen content is in the exhaust.If for some reason it thinks to much oxygen content is in the exhaust it will tell the ecm to add more fuel.The post catalytic O2 basically is used to monitor the catalytic converter function and should not adjust any air or fuel. Is the check engine light on and are any codes presnt?
Jun 10, 2010 | 1992 Chevrolet Camaro
1992 Camaro RS 305 V8, Auto
A knock is not good. Does it change when you put the car in gear? Is it loud enough to hear at idle? If it changes in gear then it is a possible cracked flywheel. If not you can idle the car pull the plug wires 1 at a time to see which one changes the sound. This will tell you which cyl has the problem. If it changes pulling the wires then it is an internal engine problem, get ready to spend some money, sorry. Good Luck.
May 07, 2009 | 1992 Chevrolet Camaro
Car dies when it warms up
check fuel pump pressure .if all is good check the ignition system.
May 03, 2009 | 1992 Chevrolet Camaro
1992 Chevrolet Camaro Z28 5.0L Oxygen Sensor Logo
Top NTK Vehicle Parts & Accessories Experts
Jeff Youtsey
Jeff Youtsey
James Spradley
James Spradley
Level 1 Expert
RAYMONDO1953
Are you a NTK Vehicle Part and Accessory Expert? Answer questions, earn points and help others
