Question about Thule 2001 Suzuki Esteem - Wagon, with factory raised roof rails - Base Rack System
Door barrol removal
Door barrol don't work
Seized engine
could have to strip it and tap piston out but lubricate or could damage barrol
Dec 04, 2012 | Briggs Stratton 020273 Elite Series...
The key for the door turns around without locking/unlocking the door
You will need to remove the door panel and take a look .
Start by removing the door handle surround it slides off- then the door mirror switch , then all the screws , then start to pray , slowly but gently begin to pull and remove the door card from the clips ..work your way round the door card in a clockwise direction making sure you don't miss the clips otherwise they will start breaking
Jun 27, 2012 | Cars & Trucks
Driver side door removal of 1997 lexus es 300
Gently don't force anything. 1st check for any visible screws on door trim & undo. remove window winder if not power window you can buy a tool for this. carfully pull the trim out from the bottom of the door & work up. You will probably find it stops near the door handle. There is probably hidden screws behind the inner door handle trim & don't forget arm rests. just be gentle & yu should work it out & not brake anything
Jun 25, 2012 | 1997 Lexus ES 300
How do I remove the rear door inner panel from my 2003 Pontiac Grand Prix? I need to check/replace the the window motor but I don't know where all the door panel fasteners are located and I don't...
To remove the door panel, remove any screws that are in the vicinity of pull handles and door pockets. These screws will be under little trim covers that you need to prise off to get to their heads. Look for the screws around the edge of the panel and also the screw in the latch release handle recess.
The lock knob, if there is one there, will have to be screwed off and then carefully work your way around the door, freeing the panel's clips from their holes in the door frame. (Doot panels are brittle and clip break out easily).
Finally the panel will probably have to be lifted out if the window slot. (If the panel does not come off, work out what is retaining it and remove that screw or slide it off the clip that is still holding the panel. Disconnect any electrical plugs behind the panel. Under the panel you will find a plastic dust sheet that is stuck to the door frame, remove this carefully, you will have to replace it before replacing the panel.
Jun 16, 2011 | 2003 Pontiac Grand Prix
How do I remove the left rear door panel from a 1996 Nissan Maxima? The window just fell down. It can be manually lifted up, but it slides back down again. It no longer mechanically works. If you can...
  • Disconnect the negative battery cable(for safety if you have power locks and windows)
  • At the bottom of the door panel remove the two screws
  • Pry up at the front edge of the power window switch pod and lift it out then unplug the electrical connector
  • Remove the inside door handle
  • Remove the screw in the door pull pocket
  • Pull the door panel away from the door far enough to disconnect the electrical connectors
May 23, 2011 | 1996 Nissan Maxima
Is there an inline circuit breaker? I can't get power to start the van. Everything is down -- no lights or anything. I have a battery saver under the front dashboard but when I press the fashing light...
check the battery cable you will find a fusible link it looks like a barrol around the wire
use a test light on both sides of the fusible link
hope this helps you
bob
May 18, 2011 | 1999 Chevrolet Express
I have a 1991 toyata camry. Sometimes the car will stop right away--other times I have to jiggle the key to get it startted. Everything is is top shape--i think the ignition key area is loose. Is that a...
Hi Evolution, The problem is common on your vehicle.... The name of the part you'll need is the ignition barrol. Behind the barrol is a plastic switch which is operated by a rod protruding through the end of the barrol
  • To be able to replace it you'll need to remove the plastic steering cowling.
  • It will be easier to remove the steering wheel first.
  • Remove the center cover of the steering wheel.
  • Punch two match marks, one onto the collumn and the other onto the wheel, as close as possible to the edge of the splines. (for easy ailignment)
  • Loosen the centre nut and using a puller, remove the steering wheel.
  • Insert the ignition key and turn it to the unlock postion, but not to the on postion.
  • Look underneath the cowling.
  • There are usually five machine screws accessed from underneath. Remove these and then remove the two halves of the cover.
  • You'll notice four blind bolts which hold the saddle which clamps the barrol
  • These need to be loosened with a cold chisel and then removed.
  • The switch is located at the end of the barrol and held in place with two screws which should be removed.
  • The switch is connected to the harness by a connecting plug and socket.
  • Unplug that connector.
  • Remove the blind bolts and then remove the barrol unit
  • Fit the replacement with new blind bolts and tighten until the heads break off (This is a safety anti theft feature to make it more difficult to tamper with).
  • Re-assemble making sure of ailignment of the steering wheel and your away
Regards Johngee10
Nov 15, 2010 | 1991 Toyota Camry
Holley 2 barrol starving for fule. Fule preasure is good filter is clean.
i do not know but give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your truck wish you the best of luck Michigan Man.
Mar 22, 2010 | 1988 Dodge D-Series Pickups
Car turns over starts but runs ruff
Replace the fuel pump either with an original or an electric.
Sep 08, 2009 | 1999 Jaguar XJ
Fitting new ignition barrel series 3 1996 316i
turn to position 1 you will see a nick nexet to the key push a thin peace of wire in nick the barrol will come out with key in it
Jan 18, 2009 | 1994 BMW 3 Series
Thule 2001 Suzuki Esteem - Wagon, with factory raised roof rails - Base Rack System Logo
Top Thule Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Thule Hardware and Accessory Expert? Answer questions, earn points and help others
