Question about DeLonghi EW0507 Oil Filled Radiator Heater
How to set clock
Don't know how to set clock to right time
I don't know how to change the minutes on my clock. It's a jeep wrangler. I've tried holding in the time button and turning tune knob, doesn't work. Thanks!
is there a h/ m with two little holes any where on the radio? usually on the right or left of the clock. if so stick a paper clip into the hole and set. if not i would try the FF and the RW buttons
Mar 11, 2013 | Cars & Trucks
T035 indiglo manual
top left button, to reveal alarm time, than the up button, which strangely is the bottom right button. very confusing.
Jan 03, 2012 | Audio Players & Recorders
The clock dial on my grasslin analog timer does not correspond to the time on the "2:00" arrow. how do i realign the clock dial to be in line with the arrow?
I don't know what the 2:00 o'clock arrow is.
KM series Arrowhead is located to right side of timer dial.
To set clock, manually rotate timer dial clockwise until current time lines up with arrowhead
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#KM
http://waterheatertimer.org/How-to-set-timers.html
If this is not your timer, then add a comment with description of timer for possible help
Jul 23, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Don't know how to set alarm or time
Please download the user's manual from here:
http://www.nodevice.com/user_manual/download_346371.html
Then read pages 14-15 for setting the time and pages 16-18 for setting the alarms. This guide is detailed and good enough.
Thanks.
gylacz
Jul 18, 2011 | Memorex MC2864 Clock Radio
I don't know how to set the clock on my hotpoint dual oven (integrated) model DB 31 - Oven came with the house we have just moved into. Thank you, Phil.
Press the CLOCK button.
Then press the ^ (UP) and (DOWN) buttons to change the time.
After the correct time is selected,PRESS the CLOCK button again.
Jun 11, 2011 | Microwave Ovens
I don`t know how to change the date and time of my sony dsc-t200
Hello there. You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen. 2 Touch [Clock Settings]. 3 Touch the desired date display format, then touch [t]. The clock settings screen appears. 4 Touch each item, then set its numeric value by touching v/V. 5 Touch [OK]. To cancel the clock setting Touch [Cancel] or [BACK] in step 5.
Sincerely, Steve TM
May 28, 2011 | Sony Cybershot DSC-T200 Digital Camera
How to set my Gilera sc125 clock display
The Gilera SC is the same as a Derbi GPR ,right? This is how I change the time on my Derbi Tap the button until it goes to the clock then hold it in until it starts flashing. Tap to change the hour then leave it for a second and it will move over to the minutes and cycle through, just tap it to stop on the right time. The batteries are **** though so don't expect it to keep the time, you'll find yourself having to set it nearly every time you start your bike.
Mar 14, 2009 | 2005 Derbi GPR 125 Racing
I HAVE A KENWOOD KDC 122 CD CAR STEREO. THERES A CLOCK ADJUSTMENT BUTTON,WHEN I PRESS THE CLOCK ADJUSTMENT BUTTON THE CLOCK "FLASHES" BUT I DON"T KNOW HOW TO SET IT,I DON"T KNOW HOW TO MOVE THE NUMBERS,IF...
For the manual for this unit head to this page
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf]
However im pretty sure you actually use the volume or tune/seek to change the numbers then when changed to what you woudl liek again simply hit the main button you used to get into the clock setting originally,
Hope this helps
Cheers
Steve
Mar 09, 2009 | Kenwood KDC-122 CD Player
Need operating instruction
I dont know where to find an instructions booklet but I can help with setting the time/date:
To set the time and date (you have to do them both together):
  • First press and hold the 'CLOCK' button until it beeps then let go.
  • You will then be required to select the year by scrolling up or down with the 'TIME SET' rocker switch on the right hand side.
  • Once you have the right time, press the 'ENTER' button, to the right of the rocker switch once.
  • You will then be required to select the the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
  • You will need to repeat this to select the date (day).
  • You then use this same process to select the time, starting with the hour and then the minute.
  • After you have finnished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
REMEMBER to press the 'ENTER' button after selecting each thing to move you on to the next thing to set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from british summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on british summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
Mar 16, 2008 | Sony ICF-C273 Clock Radio
Open Questions:
See all DeLonghi EW0507 Oil Filled Radiator Heater Questions
DeLonghi EW0507 Oil Filled Radiator Heater Logo
15 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
