Question about Epson Stylus Photo Px660
How to solve paper jam error in epson stylus photo px660 printer
3 Suggested Answers
tech-agent
  • 83 Answers
SOURCE: Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Posted on Feb 13, 2010
  • 826 Answers
SOURCE: epson stylus photo px660 with a paper jam error after dismantling it displays a printer error with all lights flashing
Paper jam problems can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation. I have observed that most people fan the paper pile to keep them dry or non-sticky. It's a wrong method because fanning the pile of papers make them go haywire and often lead to paper jam.
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point.
you can try following points.......
1.turn off the machine for at least 5 minutes and disconnect the interface cable to the computer.
2. push and hold down the "ink" button and the "paper" button and turn the printer on.
3. When the "paper" light flashes quickly release both the buttons and then immediately press and hold down the "ink" button only for at least 10 seconds.
**You will need to try this several times to get the sequence correctly.
If you need any kind of technical assistance, you can contact support cell at http://vtechsquad.com/printer-support/
Posted on Sep 11, 2012
Error: printer error. turn off then on again. for details, see your documentation.
Hi I have a similar problem with Epson px660, it does not complete the self test after powering on then it flashes all lights with a printer error of fatal code 0x71, can you assist me kindly.
Best regards
Mar 13, 2015 | Office Equipment & Supplies
I have an Epson stylus photo PX 660,which is displays an error message that,paper jam inside and in real sense there is no any paper jam inside.show me how i can solve this problem.
Check the rollers (the inlet and outlet for the paper) and blow them out with a blower,vacuum, or a can of air. That should "fixya" right up. Lmk if it doesn't and I'll get down to specifics with more info from you as well
Feb 12, 2015 | Epson Stylus Photo Px660
Hallo am mark,my printer px660 is displaying paper jam when i press ok button it display's close scanner then it says i turn it off when i close.then it displays the same text.how do i go aout it?
It may be obvious but check to see if you have paper or that it is loaded correctly in the tray.
My Epson Workforce gives a paper Jam error when I'm out of paper. Yours may be doing the same.
Feb 09, 2015 | Epson Stylus Photo Px660
How do i reset ink pad counter on epson stylus photo px660
Try taking out all the cartridges and reinserting them.
Jan 24, 2014 | Epson Stylus Photo Px660
Paper jam while there is no paper inside in EPSON printer PX660
paper ka tukda fas raha hoga ya paper sensor kaam nahi kar raha hoga unit khol kar saaf kar lena OR sensor saaf kar lena problem solve
Aug 22, 2012 | Epson Office Equipment & Supplies
Epson Stylus Photo Px660 Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
