Question about Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer
Hotpoint Ariston WD440G fault codes - Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer
3 Suggested Answers
  • 135 Answers
SOURCE: Waste hose connection hotpoint wd440g
Have you checked the filter? This can be found at the large end of the pipe. It is secured with a large jubilee clip.
Thankyou for using Fixya.
Posted on Feb 13, 2009
  • 6277 Answers
SOURCE: Hotpoint WD440G Combination washer dryer,
If it's not cured by carrying out the following GET THE TECHIE BACK IN! He/She has not fixed the fault you have paid for, plus you will have been charged for an item which the washer- and you- did not require- which would be shocking (I'm English!!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 05, 2011
Hotpoint WD440 washer/dryer wont control.when plugged in 4 lights flash and it goes to pump out . no switch has any effect. the lights flashing are the on/off ,drying high heat.reduced creases and time...
The NTC for the dryer is situated on top of the dryer heater box, fault can often be caused by a simple broken wire, they are very weak at this point.
its the sensor on the dryer
if you take off the top, its mounted on top of the dryer box, usually has a white plug with 2 black wires attached
Dec 13, 2011 | Hotpoint Ariston WD440G Front Load...
Broken blue part inside drum
Check that broken parts having any wire connections. if it is not there try to stick it without damaging the drum .
Aug 06, 2011 | Hotpoint Ariston WD440G Front Load...
All light flash machine will not start
Replace the C17 capacitor on the PCB. 56p from Maplin. Get a 1000uf 16v. Works a treat. Common problem.
Dec 08, 2010 | Hotpoint Ariston WD440G Front Load...
Hotpoint Washer/Dryer,Aquarius WD440 will not take softener.
take out small either blue or green filter from detergent drawer where you would normaly put the liquid softner and run it under hot water tap my guess is that the small pipe within is clogged this should clear it
Oct 13, 2009 | Hotpoint Ariston WD440G Front Load...
Machine will not spinning
check carbon brushes and drain pump for blockages unplug from mains
Jun 11, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
Feb 12, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint WD440G In wash cycle and blows all household plugs
syphon out the water by getting the end of the drain hose into a basin and putting it lower than the water level. a few shakes usually gets it flowing. you probably have a short circuit. my guess would be the heater box/element to start.
Jan 30, 2009 | Hotpoint Ariston WD440G Front Load...
Wd440g Hotpoint - in wash cycle and is blowing all the household
you will have a short circuit somewhere. usually the dryer box, but to get the water out you need to put the end of the drain hose lower than the water level into a basin to syphon it out.
the heating element of the dryer sometimes come loose on these machines and can be the cause of a short.
Hotpoint wd440 washer dryer fault
sounds like the heating element of the dryer may have come loose and is shorting against the metal dryer box on top of the drum.
engineer job if you're not electrical
Jan 25, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer Logo
16 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
