Question about Clothing Accessories
Design problem to make a accident by hooking ties
A hook of shoe hooked the other ties of another shoe while I walk and I have fallen down several times because of same problem and I have gotten bruies. It must be a design problem. I want to attatch photos to explain details, but here is no way to attatch photos.
    Master:
  • 965 Answers
A pair of pliers will fix this. Bend the end of the hook in to stop it from catching on the other. If all you got is some bruie, this is the time to fix this before you get an injury or broken bone.
Posted on May 27, 2014
SOURCE: diagram of the vacuum hook-up
Try http://www.starquestgarage.com/ they have several of the service manuals there.
Posted on Oct 13, 2008
SOURCE: brake pedal goes down when applying pressure while
You have a leaking brake booster. If you don't plan to do this yourself, it should go to a repair shop.
Posted on May 05, 2009
81vasquez
  • 34 Answers
SOURCE: remove hooks to get headliner down
there should be a little cap that removes then you will see a screw
Posted on Jun 06, 2009
  • 161 Answers
SOURCE: brake shoe springs
brake springs are usually color coded for convenience, so that should help. don't be afraid to look online for a diagram, grab a buddy that knows something, or buy a repair manual if you need it.
Posted on Jun 11, 2009
kidspeedy
  • 321 Answers
SOURCE: passenger will roll down but not up
sometimes when this happens people think its the switch.
but in the process of removing the motor it is kind of like bumping the motor in away that it will work again for a very short time and stop working again.
the problem is in the motor and replacing the motor will remove the problem.
Posted on Jun 12, 2009
How do i make a banded treble stitch please
  1. Yarn over hook three times, then insert hook into next stitch.
  2. Yarn over hook and draw yarn through stitch (there are five loops on the hook).
  3. Loop yarn over hook and draw through two loops (there are now four loops remaining on the hook).
  4. Yarn over hook and draw through two loops (there are now three loops remaining on the hook).
  5. Yarn over hook and draw through two loops (there are now two loops remaining on the hook).
  6. Again, loop yarn over hook and draw through the last two loops on the hook (there is now one loop remaining.)
  7. This completes one double treble crochet.
Jan 30, 2015 | PTAJ Marketing Crocheting Stitches
What is Kahle Snelled Hooks
The Eagle Claw Snelled Kahle Hook is a pre-snelled kahle style hook designed for live and cut baits when fishing in saltwater or freshwater. The snelled kahle hook, from Eagle Claw, are constructed around an offset, up-eye kahle hook which exhibits a wide bend that is ideal for using live, cut or prepared baits. The Kahle style hooks are preferred by some anglers due to their tendency to hook fish more securely. Highlighted by a wider gap, the Kahle hook design places the hook farther back in the fish's mouth to eliminate tearing out the lip. Because the Kahle hook's eye and point are on the same plane, the hook is much easier to remove. The hooks are pre-snelled with premium monofilament line offering an easy alternative to tying up your own snelled hooks. We offer the #147 Eagle Claw Snelled Kahle Hooks in ten sizes: 14, 12, 10, 8, 6, 4, 2, 1, 1/0 and 2/0. The hooks are bronze in color and come 6 per pack.
Feb 21, 2014 | Eagle Claw 147 Kahle Snelled Hooks
Installing all new drum brakes ford f100 took picture and installed driver side eveything went ok pasenger side a nite mare the spring hooks face the same way for both sides cant figure out how to hook...
Did you by chance mix up the shoes,adjuster etc? Short shoe (primary) will be closest to front of vehicle.(right side of backing plate.) Larger shoe to rear. Seen them put on backwards many times when changing from one side to the other. If you only took picture of drivers side, and your using that for reference, adjuster, shoes etc, will be wrong when you go to opposite side of truck. What year is this truck?
May 25, 2010 | Ford F-100 Cars & Trucks
Need repair guide for rear brakes 1990 E350 Ford
Ford Full-Size Vans 1989-1996 Repair Guide
Brake Shoes - REMOVAL & INSTALLATION
Light Duty Systems
  1. Raise and support the vehicle and remove the wheel and brake drum from the wheel to be worked on.
If you have never replaced the brakes on a van before and you are not too familiar with the procedures involved, only dissemble and assemble one side at a time, leaving the other side intact as a reference during reassembly.
  1. Install a clamp over the ends of the wheel cylinder to prevent the pistons of the wheel cylinder from coming out, causing loss of fluid and much grief.
  2. Contract the brake shoes by pulling the self-adjusting lever away from the starwheel adjustment screw and turn the starwheel up and back until the pivot nut is drawn onto the starwheel as far as it will come.
  3. Pull the adjusting lever, cable and automatic adjuster spring down and toward the rear to unhook the pivot hook from the large hole in the secondary shoe web. Do not attempt to pry the pivot hook from the hole.
  4. Remove the automatic adjuster spring and the adjusting lever.
  5. Remove the secondary shoe-to-anchor spring with a brake tool. (Brake tools are very common implements and are available at auto parts stores). Remove the primary shoe-to-anchor spring and unhook the cable anchor. Remove the anchor pin plate.
  1. Remove the cable guide from the secondary shoe.
  2. Remove the shoe hold-down springs, shoes, adjusting screw, pivot nut, and socket. Note the color of each hold-down spring for assembly. To remove the hold-down springs, reach behind the brake backing plate and place one finger on the end of one of the brake hold-down spring mounting pins. Using a pair of pliers, grasp the washer type retainer on top of the hold-down spring that corresponds to the pin which you are holding. Push down on the pliers and turn them 90° to align the slot in the washer with the head on the spring mounting pin. Remove the spring and washer retainer and repeat this operation on the hold down spring on the other shoe.
  3. Remove the parking brake link and spring. Disconnect the parking brake cable from the parking brake lever.
  4. After removing the rear brake secondary shoe, disassemble the parking brake lever from the shoe by removing the retaining clip and spring washer.
To install:
  1. Assemble the parking brake lever to the secondary shoe and secure it with the spring washer and retaining clip.
  2. Apply a light coating of Lubriplate®, or equivalent, at the points where the brake shoes contact the backing plate.
  3. Position the brake shoes on the backing plate, and install the hold-down spring pins, springs, and spring washer type retainers. On the rear brake, install the parking brake link, spring and washer. Connect the parking brake cable to the parking brake lever.
  4. Install the anchor pin plate, and place the cable anchor over the anchor pin with the crimped side toward the backing plate.
  5. Install the primary shoe-to-anchor spring with the brake tool.
  1. Install the cable guide on the secondary shoe web with the flanged holes fitted into the hole in the secondary shoe web. Thread the cable around the cable guide groove.
  2. Install the secondary shoe-to-anchor (long) spring. Be sure that the cable end is not cocked or binding on the anchor pin when installed. All of the parts should be flat on the anchor pin. Remove the wheel cylinder piston clamp.
  3. Apply Lubriplate®, or equivalent, to the threads and the socket end of the adjusting starwheel screw. Turn the adjusting screw into the adjusting pivot nut to the limit of the threads and then back off 1 / 2 turn.
Interchanging the brake shoe adjusting screw assemblies from one side of the vehicle to the other would cause the brake shoes to retract rather than expand each time the automatic adjusting mechanism is operated. To prevent this, the socket end of the adjusting screw is stamped with an "R" or an "L" for "RIGHT" or "LEFT". The adjusting pivot nuts can be distinguished by the number of lines machined around the body of the nut; one line indicates left-hand nut and two lines indicate a right-hand nut.
  1. Place the adjusting socket on the screw and install this assembly between the shoe ends with the adjusting screw nearest to the secondary shoe.
  2. Place the cable hook into the hole in the adjusting lever from the backing plate side. The adjusting levers are stamped with an R (right) or a L (left) to indicate their installation on the right or left-hand brake assembly.
  3. Position the hooked end of the adjuster spring in the primary shoe web and connect the loop end of the spring to the adjuster lever hole.
  4. Pull the adjuster lever, cable and automatic adjuster spring down toward the rear to engage the pivot hook in the large hole in the secondary shoe web.
  5. After installation, check the action of the adjuster by pulling the section of the cable guide and the adjusting lever toward the secondary shoe web far enough to lift the lever past a tooth on the adjusting screw starwheel. The lever should snap into position behind the next tooth, and release of the cable should cause the adjuster spring to return the lever to its original position. This return action of the lever will turn the adjusting screw starwheel one tooth. The lever should contact the adjusting screw starwheel one tooth above the centerline of the adjusting screw.
If the automatic adjusting mechanism does not perform properly, check the following:
  1. Check the cable and fittings. The cable ends should fill or extend slightly beyond the crimped section of the fittings. If this is not the case, replace the cable.
  2. Check the cable guide for damage. The cable groove should be parallel to the shoe web, and the body of the guide should lie flat against the web. Replace the cable guide if this is not so.
  3. Check the pivot hook on the lever. The hook surfaces should be square with the body on the lever for proper pivoting. Repair or replace the hook as necessary.
  4. Make sure that the adjusting screw starwheel is properly seated in the notch in the shoe web.
Heavy Duty Systems
  1. Raise and support the vehicle.
  2. Remove the wheel and drum.
  1. Remove the parking brake lever assembly retaining nut from behind the backing plate and remove the parking brake lever assembly.
  2. Remove the adjusting cable assembly from the anchor pin, cable guide and adjusting lever.
  3. Remove the brake shoe retracting springs.
  4. Remove the brake shoe hold-down spring from each shoe.
  5. Remove the brake shoes and adjusting screw assembly.
  6. Disassemble the adjusting screw assembly.
  7. Clean the ledge pads on the backing plate. Apply a light coat of Lubriplate®, or equivalent, to the ledge pads (where the brake shoes rub the backing plate).
continue...
Jan 15, 2010 | 2002 Ford E350
Can the consew 339rb-1 be used only with 1 needle?
this is the specifications for the 339rb-3. they sould be close to yours, if you can put two seperate needles in and the machine hase one hook and bobbin case then I would say you can use one needle, if you have two hooks and bobbins, I would say no, you may want to thread with one and just hand turn for a few stiches to sew hoe it reacts, leave the bobbin door open so you can watch the hook.
Specifications
  • Two needle mechanism readily makes two parallel lines of stitches
  • Compound feed, walking foot mechanism insures even feeding of material
  • Large hooks and bobbins assures longer operation between bobbin changes
  • Centra-Lube® semi-automatic lubrication system
  • Automatic hook lubrication
  • Oil fed take-up
  • Simple adjustment permits raising and lowering of the center foot which allows for sewing different thickness of material
  • Safety clutch protects the hooks from being damaged
  • Various needle gauges available
  • For sewing light to heavy-weight materials such as leather, vinyl, upholstery, synthetics, canvas, vinyl and various coated and laminated products
  • Designed for stitching such products as auto, boat and furniture upholstery, tarpaulins, covers, sails, tents, camping trailer covers, awnings, umbrellas, tops, bags, luggage, handbags, travel ware accessories, sports and camping equipment, wearing apparel, outdoor clothing, canvas shoes, slippers, orthopedic appliances, etc.
  • Suitable for double needle seaming, binding, taping and piping operations
Aug 27, 2009 | Consew 339RB-3 Sewing Machine
I NEED TO HOOK UP MY CS 4000 AMPS
If you are trying to use 3 amps to drive a single cabinet, it can not be done. Bridging amplifiers requires a specific circuit design for that application. There is no way to hook up multiple amps to a single speaker.
Dan
Mar 04, 2009 | Peavey CS 1400 Amplifier
Rock Climbing Harness with Auto Belay, where to hook on?
Easiest is to hook the swivel carabiner to the belay loop.  This is a sewn loop of webbing that connects the leg loops to your waist belt.
Dec 02, 2008 | Black Diamond ATC Belay/Rappel Device Fall...
Clothing Accessories Logo
66 people viewed this question
Top Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
