Question about Sewing Machines
I want to know if the Singer 80227 Vertical Needle Zipper Foot works with Singer sweing machine model 1275
It should work on all Singer vertical needle sewing machines and other brands using a side fastening thumb screw including Kenmore, White and Signature.
If your 1275 is vertical then I don't see an issue here.
Posted on Feb 16, 2014
4 Suggested Answers
SOURCE: singer sweing machine 5430c not letting the thread
can u tell me how to overlock with singer 5430 c
Posted on May 29, 2009
  • 76 Answers
SOURCE: alignment of needle.
make sure the needle is positioned correctly and all the way up into the deedle slot. lower by hand and check again, if still doing so you can tilt the needly slightly befor tightning the screw. lower by hand again an see
Posted on Aug 27, 2009
  • 96 Answers
SOURCE: Kenmore sewing machine and zipper foot attachment
refer to site feedback@sewconsult.com
Posted on Dec 14, 2009
Why is needle hitting zipper foot on left side only?
When the needle is set on the center position, is it centered or is it slightly off center? If so, then the mechanism needs to be adjusted so that the needle is perfectly centered. When it is off-center, you will get the problem you are experiencing with hitting one side of the zipper foot. May want to take it in for service.
Mar 13, 2016 | Singer 4411 - Heavy Duty Model Sewing...
Iwant to sew a separating zipper on a coat. what does the zipper foot look like for singer model 3116?
Just like the regular working foot, most zipper feet look the same regardless of machine. At least, the part of the foot that is actually in contact with the work: small, solid--no thread slot or needle well in the middle--and a small notch on each of the left and right sides.
Jul 16, 2014 | Singer 3116 Simple
Change needle position
http://www.singerco.com/uploads/download/438_3116.pdf see p. 52. You change the position of the zipper foot, not the position of the needle, with this machine.
Feb 13, 2014 | Singer 3116 Simple
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
I hear a knocking sound on my machine when I sew, and sometimes the thread pulls and messes up the fabric... any ideas?
The bobbin case and shuttle need to be cleaned and the machine oiled.
When you thread the machine, always have the presser foot up.
When sewing and you need to reposition the fabric, make sure the needle is down into the fabric before raising the presser foot.
When the presser foot is up, the tension opens and does not control the flow of the thread and you get a messy stitch or a jam.
Refer to page 84 of the manual for your machine. If you do not have a manual, download one free at the Singer Co. website. It is important to
follow the instructions in the manual.
Feb 24, 2010 | Singer 3116 Simple
My 8280 modle singer: I sewed a zipper for a shirt, but the needle hit the hard part of the zipper, so the needle broken, when I replaced a new needle, but found that that machine stuck, even I push the...
If you are not able to free this easily, you really should consider taking it to a service technician to look at it in case you do more damage to the needle bar and elsewhere trying to fix it yourself.
Sep 07, 2009 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
