Question about Air Tools & Compressors
Hi ive got a marmet 1987 coach built pram i would loke to have ago at re-spraying my grey hood and apron like some feed back on best spray paint as i imagine it carn't be regular paint
tcdchameleon
  • 9 Answers
SOURCE: Spraying troubles
Off hand I would say that you have the wrong spray tip for the paint that you are spraying or that the tip is worn. Another thing that it could be is the little piece of rubber behind the tip is worn or missing. My first suggestion is check the tip size with the recomendations of the paint that you are spraying (You will find this on any specification sheet from the paint manufacturer.. If the size is correct replace the tip. A new gasket comes with a new tip. Hope this helps.
Posted on Jan 20, 2009
  • 35 Answers
SOURCE: Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Posted on Feb 26, 2009
SOURCE: i have been given a navy blue silver cross coach
The sticker on the bottom is only the chassis number and usually the date of manufacturer. Is the pram one where the body detaches from the wheels and do you know how old it is? Or is it the boat shaped body with big wheels, which doesn't detach from them? (Similar to the picture on here of the Balmoral). Or is it one where the body detaches from the body? If you look on EBay under Silver Cross prams you should be able to identify the model. There are also aprons often for sale on there too.
Posted on Jul 21, 2009
digritz
  • 530 Answers
SOURCE: MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
Posted on Jun 01, 2010
  • 5 Answers
SOURCE: We are having trouble getting
when you pull the trigger can u see the needle moving backward? if so, then it's either the paint is too thick compare to the nozzle size or the passage for paint is blocked. try to take the nozzle, needle and the cup off and give it a good clean!
Posted on Sep 08, 2011
Remove Spray Paint Over Spray on Vehicle
Could try grim and wax remover/prep for auto bodies. Auto stores have it. Then polish/ wax the spot.
Mar 21, 2014 | 2004 Dodge Ram Pickup 1500
Footmuff / apron and hood
Hi Kelly
We would recommend you make contact with Baby Style for assistance.
BabyStyle Contact Us
Jan 04, 2014 | Babystyle latina 3in1 pram
Where to find parts of the paint zoom gun sprayer?
Hi, parts easily can be found on amazon, here Amazon com paint zoom gun sprayer parts take a look. Wish you best of luck. Dean
Jul 06, 2012 | Air Tools & Compressors
Hey yall i got a sharpe finex3000 hvlp spray gun model sh-880 1.4 finish gun. and ive used this gun before and i cant remember how 2 set it up etc or what the best working pressure is. anyways i was tryen...
There is a step by step description in the manual of the Finex3000 itself (incl. pressure set-up, etc...). In case you don't have it anymore, you can look online: http://sprayfinishingstore.com/manuals/
Jul 25, 2011 | RTO Sharpe Finex 3000 Hvlp Gravity Auto...
Im lookingg for paint codes for the black and grey green paints for retouching
I dont think kawasaki do paint codes go to a auto paint supplier and get a colour match,if it is not right you usually get a second match for free.or contact a quality motorcycle paint spray company they may have the code sorted from past jobs.
Mar 13, 2010 | 1987 kawasaki GPX 750 R
Pram been stored for 3 years,needs hood cleaning,hood been down so u can see marks
There is someone selling a restorative spray for hoods and aprons in varies shades on ebay. Just used it today and very pleased with results.The spray is called Magix Color and I know you can also get this on the highstreet or from a boot repairer/leather shop.
Feb 02, 2010 | Silver Cross Balmoral Pram Carriage...
Hi, have old 60's dolls pram, dont know make. I
Use some CLR to get rid of the rust.... Sand down a little and then spray paint....
Sep 18, 2009 | Baby Gear
I have been given a navy blue silver cross coach built pram, i need to find out what kind it is because it needs a apron. it has a sticker on the bottom of it with numbers on but this means ? to me. please...
Jul 17, 2009 | Silver Cross Balmoral Pram Carriage...
Silver cross
Babybirds.co.uk stock a full range of replacemnet parts for silver cross coach built prams baby and dolls or heritage prams there is a link through the silver cross web site. but they do tend to a little more expensive.
Nov 06, 2008 | Silver Cross Balmoral Pram Carriage...
Air Tools & Compressors Logo
23 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
