Question about Cameras
Meike speedlite mk950 pilot no working - Cameras
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Speedlite 580 pilot light on but flash wont fire
More info needed: Will the flash fire when you push the test button? Have you rest the camera you're using to factory defaults while the flash is mounted on the camera and turned on?
Jan 06, 2014 | Canon Speedlite 580EX II TTL Flash
I do not have the manual. Where can I download?
Question is: is there a mania? Because Meike does not send a manual with the MK-40N. Perhaps you try to get a manual of the Nikon SB-910 for free with Nikon USA. Because it won't be the same, but you can learn what that speed light can and how to set it. You than can find the same things on the MK-40N more easy.
Nov 19, 2013 | Universal Meike MK-410N 3W 5600K TTL Flash...
Pilot light not lighting on 420ex speedlite canon flash
This may seem dumb to ask but have you made sure all batteries are fresh (even new ones can be bad), they\'re inserted correctly observing polarity and the contacts are clean in the flash? (You can clean them using a clean, dry pencil eraser and a Q-Tip dipped lightly in alcohol.)
Also, try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Feb 28, 2013 | Canon Speedlite 420EX TTL Flash
Speedlite 430EX II pilot red light wont turn off wont fire
Try mounting the flash on your camera, turn both on and reset your camera to factory default settings in your camera menu settings.
Feb 13, 2013 | Canon Speedlite 430EX TTL Flash
Speedlite 430ex, pilot light on, flashes when I hit the pilot, but will never fire when taking a picture....the "ready" light below the red pilot light never turns on
Typically, it means your batteries are low but I am sure that you know that already.
The next cause is a mechanical failure. The flash has capacitors that **** up the battery power until they have a full charge and the trigger the ready light. Therefore, if your batteries are good then it is likely that the capacitors are disconnected or have failed. Eitherway, you will most likely have to send it out to a Canon service center. You can find service centers at www.canonusa.com.
I hope this helps. Good luck!
Jan 16, 2011 | Canon Speedlite 430EX TTL Flash
Canon 50D doesn't recognize new Speedlite 430EX II. Flash power is on and pilot releases flash.
Check the contacts on both the camer and the lens. I usually clean mine with methylated spirits or isopropyl alcohol. I have to do this every 3 months or so as dirt or even oils from your hands can stop the contacts from working properly.
Oct 30, 2010 | Canon Speedlite 430EX TTL Flash
Why wont the pilot light flash on at all ? everything else works but speedlite wont flash?
Because of the high voltage inside the camera, that will have to be sent to Canon for repair.
Nov 08, 2009 | Canon SPEEDLITE 580EX TTL Flash
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
