Question about LG BP530
Lg bp530 will not turn on and stays at hello screen
Hello, I have an LG 47LV5400 LCD TV. TV goes on fine but then the screen goes black after 15 to 45 minutes.
Hello... You have LEDs in the backlighting circuit going bad. If you can find a service center that does LED strip replacement, it might be repairable. If you attempt to repair it yourself, you risk damaging the LCD screen, as they are very fragile. I hope this helps!
Nov 26, 2017 | LG Televison & Video
What can I do if my LG monitor does not stay on
Hello, first of all try this monitor on different pc/laptop.
If it behaves the same then you can see if it is stays on for a sec or two then it is inverter, if it stays on for several seconds then it can be background light. In any case it has a problem with power supply or panel so if you are not familiar with electronics please visit proper service center, due to potential electrical shock and hazard.
Hope this helps.
Oct 24, 2014 | LG Computers & Internet
Why does my lg dvd player mod bp530 keep freezing?
Blu-Ray players are really a computer and they crash more than other; mine does this and I have to power cycle it to get it back running. very irritating but you can thank all that copyright "protection" software running on it..
You could have a funky disk; does it do it to all of your disks?
May 19, 2014 | LG Televison & Video
WiFi connection issues
I think you can try to reset the router and reconfigure it.
Press and hold the reset button on the router for 30 seconds. Release the button. Unplug the power and plug it back it. Wait for 30 seconds.
Connect the modem to the Internet port on the router. Computer to port 1 on the router.
Open the setup page of the router using 192.168.1.1 and configure the router manually.
Check this article for more information about Linksys EA3500 router Installation
Apr 10, 2014 | LG BP530
How do i make LG BP530 Multizone ?
Making any adjustments to the settings to any BDPs, is not possible without its software passcode. It is best to contact any authorized service center for LG, because, company will provide this passcode to them only, and not publically.
Aug 31, 2013 | Televison & Video
I have a LG DVD Recorder, Model no. RH399H. When I turn it on it only goes as far as the greeting screen "HELLO" and nothing further. Could you please tell me what could be the problem
Sep 13, 2010 | LG Audio Players & Recorders
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
Turns on but immedatly turns off, screen is black and the power does not stay on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 23, 2010 | LG 50PG20 50 in. Plasma HDTV
3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
LG BP530 Logo
126 people viewed this question
Computer Repairing
Computer Repairing
