Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
ICE TRAY STOP - Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Makesvery little ice
Make sure you pull the ice cubes periodically from the back of the ice tray to the front. If the back of the tray is piled past a certain point the unit will think the ice tray is full and stop ice production. This was a design flaw most samsungs. Hope this helps _MJ_
Apr 27, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice maker will not stop,even when the tray is full of cubes.. will only stop if arm is put up..
The ice tray arm is mechanical. It is pushed up by the ice cubes. Try bending the arm down so it makes contact with the ice cubes sooner and gets pushed up sooner when it reaches up posistion it should stop.
Mar 29, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker on GE Profile quit working. Emptied tray of ice and put back in, not producing any ice.
Make sure the "Full" actuator is in the down position. Sometimes when the ice tray is removed, the full actuator flips up to stop ice production.
Hope this helps.
Aug 18, 2009 | GE Refrigerators
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
My Ref.wount make ice
I have a friend who has a kenmore coldspot Model# 7028999 Serial # EJ5040321 and it won't make ice there is water to the coldspot from the angle stop. A new pump was acquired and installled, but no water reaches the ice cube tray area. When ewater is poured into the ice cube tray area by hand, the ice cubes are made and the machine dumps them into the ice holder. What is the reason for no water from the angle stop to the ice tray? could there be an electric switch in addition to the pump device? Bob 512-762-4585
Apr 26, 2008 | Refrigerators
Ice Maker overflow
my icemaker overfill can you help
Oct 31, 2007 | Refrigerators
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
12 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
